Old Jan 26, 2022 | 07:49 PM
sbeamer's Avatar
sbeamer
What is this ? "crankcase vent box with the latest non serviceable one to save your upper oil pan seal."
I saw this on a new post. The OP has a 2017. I have a 2012. Is this applicable to my year as well ?
Old Jan 26, 2022 | 08:19 PM
Boaterguy's Avatar
Boaterguy
Hmmm. I seem to remember a recall some time ago on my 2015 power stroke concerning the crankcase ventilation oil separator assembly. Is this what you are referring to?
Recall FSA17M04
Old Jan 26, 2022 | 10:15 PM
FishOnOne's Avatar
FishOnOne
Your 2012 has a non serviceable crankcase box so no need to worry.
Old Jan 28, 2022 | 10:05 AM
Romark's Avatar
Romark
I saw the same post and was curious as well. I tried an internet search but didn't come up with anything. I think it was on the thread titled, "Bought my first 6.7" or something like that.
Old Jan 28, 2022 | 11:15 PM
superduty4x4's Avatar
superduty4x4
Look at the CCV box above your driver's side valve cover, it's a black rectangular box behind the fuel filter. Take a look at the top center of the image below, it's the black box with 2 white stickers on it:
Take a look at what's on your truck, if you can see bolt heads on the top side of the CCV you have the style with a serviceable filter that is known to fail. No bolts means you are good to go.
Also check out the following YouTube video:
Old Jan 30, 2022 | 08:34 AM
Gomerpyle's Avatar
Gomerpyle
What do you mean by no bolts you are good to go?? Does it mean it doesn't need to be replaced?? I thought if it wasn't serviceable, the whole thing needed replacement sometime after 75,000 miles. Which is correct?
Old Jan 30, 2022 | 10:22 AM
FishOnOne's Avatar
FishOnOne
If your unit doesn't have bolts that means it's the non serviceable type and should be good for the life of the truck.
Old Jan 30, 2022 | 11:03 AM
Dirthawg2.0's Avatar
Dirthawg2.0
Here is a thread where we discussed this last year. Lots of up close photos to look at. And just to be clear there are now 3 different types of CCV boxes on the 6.7.
https://www.ford-trucks.com/forums/1...separator.html
Old Jan 31, 2022 | 01:35 PM
Gomerpyle's Avatar
Gomerpyle
^^^ thanks. I was under the impression that they ALL needed replacement after a certain amount of time, just some were serviceable & some weren't.
Old Jan 31, 2022 | 08:34 PM
sbeamer's Avatar
sbeamer
Not sure what's going on with my post. Right NOW is the 1st time I've been able to see any of the replies. When I would click on the thread, it went directly to my account page. But only on this thread ! WTF? Anyway, if you see I have re posted basically the same thread, you'll know why.
halaferd
23
May 19, 2014 08:42 PM
electech_72
May 27, 2012 12:09 AM
scraprat
Modular V10 (6.8l)
Jun 3, 2010 05:32 PM
helpfulguy
Mar 28, 2006 08:26 AM
