Sponsored by: Real Truck
Pulling to the left hard when braking??
Old Jan 26, 2022 | 01:59 PM
kristin smith's Avatar
kristin smith
I have a 2012 f350 it’s pulling to the left when braking. I have replaced calibers brakes brake lines ball joints ujoints on both front sides replace the proportioning abs valve and a stabilizer bar. I also rotated the tires.. I can’t figure out what is causing it.. I’m lost any ideas??
Old Jan 26, 2022 | 03:08 PM
Djosbun's Avatar
Djosbun
Meaisr brake rotor temperatures at all four wheels while driving & braking in a straight line. The left side/right side temp difference should be within a few degrees of each other. Could have a bad hydraulic hose causing the caliper to not fully retract.
-- Dave
Old Jan 26, 2022 | 03:21 PM
redford's Avatar
redford
FTE Leadership Emeritus
I had an F-150 that was pulling hard right while braking. I had a shop inspect the brakes and suspension, it was all perfect. Then the mechanic told me my truck had "radial pull". His explanation didn't make sense to me, but the cure was to rotate the tires. Since the issue showed up after a tire rotation, it sort of made sense to me. He rotated the tires front to opposite rear and the pull vanished.
Old Jan 27, 2022 | 12:03 PM
kristin smith
I rotated the tires and also changed the brake lines
Old Jan 27, 2022 | 06:47 PM
RV_Tech's Avatar
RV_Tech
Rotors okay, equal wear each side? Does our truck track straight ahead when just coasting. No pull to left when not braking. You've eliminated the obvious.
Old Jan 27, 2022 | 08:58 PM
Djosbun's Avatar
Djosbun
If you replaced all of the brake system components at each corner, and each suspension component is PERFECT, then I suggest finding a new mechanic.
-- Dave
JNG6
Feb 23, 2018 10:52 PM
polarisman
Apr 20, 2014 05:21 PM
Brent M.
Mar 27, 2008 01:36 PM
blong
Jan 14, 2007 08:36 PM
RobertJohn
Nov 24, 2004 06:09 PM
