Sponsored by: Real Truck
clunk when braking!
Old Mar 26, 2008 | 08:26 AM
Brent M.'s Avatar
Brent M.
Question clunk when braking!
iam having trouble figuring this one out....(01 f350 4x4)when i apply my brakes,i get a clunk type sound from underneath my feet......it doesn't do it all the time....also,if i get it to do it,it seems like i have to wait a bit to get it to do it again...iam thinking it has something maybe to do with brakes/calipers...it almost seems like it has to"reset itself" so to speak before it will do it again.I quickly poked my head under there this morning before work,and i did notice that the caliper seemed like it had a little movement in it...it was the same on the passenger side though,and i only get the noise from the drivers side...just wondering if anybody had any ideas...iam sure it is not link end bushings,stabilizer bushings,ball joints,etc.....because i just recently did all that...it definately seems to be in the brake setup somewhere....thanks for any input!
Old Mar 26, 2008 | 09:35 AM
danyzf95's Avatar
danyzf95
Maybe you have a loose brake pad in the caliper, allowing the pad to chuck inside of the caliper making a noise each time you apply the brakes.
Old Mar 26, 2008 | 10:21 AM
twags6's Avatar
twags6
Your ball joints are worn. When mine started to go, it would only do it when braking pretty hard, but it was a nice loud thud. Jack the front end up and try moving the tires around with a long 2x4 and see if the joints have play. If they do, RacerGuy has a good writeup on ball joint replacements. https://www.ford-trucks.com/forums/3...ll-joints.html
Old Mar 26, 2008 | 10:33 AM
2002f2507.3LPS's Avatar
2002f2507.3LPS
my vote is ball joints, i had the same problem when commin to a stop on my truck as well. changed out the ball joints, had an alignment, and the truck drove so much nicer afterwards. got grees fittings to
Old Mar 26, 2008 | 12:06 PM
Keith Smith's Avatar
Keith Smith
Don't rule out a sticking caliper pin. Guzzle has a good write up on those. OP said he just did ball joints.
Old Mar 26, 2008 | 12:33 PM
twags6's Avatar
twags6
Hmmm, guess I read too fast. Keith is probably right.
Old Mar 27, 2008 | 01:38 AM
Brent M.'s Avatar
Brent M.
i only have maybe 5000km on ball joints...i'm sure that isn't it...it isn't a loud noise either.....this sticking caliper pin kinda makes sense...wht is the best way to check this?....thanks for the ideas gentlemen!
Old Mar 27, 2008 | 08:01 AM
5.4L to Freedom's Avatar
5.4L to Freedom
I have do disagree with the ball joint idea, though it is possible, I just did my balljoints 25K ago and am experiencing the same thing by the sounds of it. Only mine seems to be coming from the rear brakes
Old Mar 27, 2008 | 08:14 AM
empiretc's Avatar
empiretc
i have the same deal, coming from the rear driver side. it started right after i changed rotors/pads/calipers. I have since learned to live with it.
Old Mar 27, 2008 | 08:36 AM
ironmine's Avatar
ironmine
Intermittent noise under your feet while braking .... a "thump" .... driver or passenger side ... comes up often here on this forum. In addition to all those things you already changed, some people have said the cab mounting bolts/bushings/etc. I've never even looked at mine, but I will.
There should be no play in the caliper area, no? The calipers are bolted on, and the pistons/pads should be snug against the rotors.
I didn't think you would hear a sticking caliper slide pin "releasing." When we apply the brakes, isn't the movement only hundreths of an inch?
I learn new stuff on this forum everyday.
Let us know what you find.
Old Mar 27, 2008 | 08:44 AM
Mercury45's Avatar
Mercury45
I say its a sticky caliper... does the truck pull to one side or another?
Pull the caliper pins and grease them up good... it wont hurt to do anyway
if you want to do the ball joints here is a write up i did on that on 99-04 trucks 250 +
http://www.angelfire.com/fang/mercury/ball.pdf
kenny
Old Mar 27, 2008 | 10:10 AM
5.4L to Freedom
Not all the time but when it does, oh boy does it ever. She just kind of goes where she wants and I hope to god I can turn that steering wheel fast enough!
Old Mar 27, 2008 | 10:37 AM
Mercury45's Avatar
Mercury45
clean your caliper slide pins then and grease them
kenny
Old Mar 27, 2008 | 12:35 PM
5.4L to Freedom
kenny
THANK YOU funny how these SD's act like a woman when all they need a little lube...
Old Mar 27, 2008 | 01:36 PM
Mercury45's Avatar
Mercury45
your caliper pins may have rubber things on them, I removed mine cause they were binding up..
use disc brake caliper lube, not never seaze
kenny
meier63
Mar 6, 2010 10:04 AM
lzrj
Aug 24, 2009 09:01 PM
SteelHorse08
2004 - 2008 F150
15
Mar 8, 2008 03:57 PM
1Knight
Sep 25, 2006 05:29 PM
JHaefele
Nov 17, 2003 01:43 AM
