Code 1280! Help!!!!
Old Jan 25, 2022 | 05:05 PM
Patriot381's Avatar
Patriot381
Code 1280! Help!!!!
Hello everyone! I am in need of help, I have replaced every sensor and most of the pigtails on my 97 f350. It has a 7.3L and I recently had the PCM rebuilt. Sending it back to the company for testing. Hoping that they just didn’t program it correctly. I am getting only 1 code and that is P1280. It is trying to start but it just not firing up, when trying to fire it up it blows out white smoke. Probably due to the dealership who worked on my truck last. They didn’t tighten up the down pipe all the way. Brand new glow plugs and relays. I checked to make sure the relay was working and it has power. I Have checked all the wiring diagrams to make sure I wired it correctly and there are no burnt wires. It was running before I had the PCM rebuilt. The old PCM had a few acidic leaks, the only other thing I replaced was the IPR and it is not throwing a code for anything but the P1280. Please if you have ideas or suggestions I would appreciate them. I couldn’t find anything similar through the 7.3 threads.
Old Jan 26, 2022 | 08:25 AM
oldbird1965's Avatar
oldbird1965
Try this chart: https://drive.google.com/file/d/0Byb...aSZWqFUID4ME6g
Old Jan 26, 2022 | 08:36 AM
Patriot381's Avatar
Patriot381
Originally Posted by oldbird1965
Thanks for sharing this, but I have already tried this.
Old Jan 26, 2022 | 09:36 PM
96 OBS's Avatar
96 OBS
Where are you located? If it’s below 60 where you are plug the block heater in for 2-3 hours and try again
Old Jan 26, 2022 | 09:59 PM
Patriot381's Avatar
Patriot381
Arkansas. I will definitely try that when I get my PCM back. Thanks. I found it today, it was tucked underneath a bunch of wires, hidden.
Old Jan 27, 2022 | 12:10 PM
BWST's Avatar
BWST
Got Data?
How are oil and fuel levels?
What is your fuel pressure?
Does it start with the ICP unplugged?
What is ICP and IPR% while cranking?
Old Jan 27, 2022 | 01:24 PM
Patriot381's Avatar
Patriot381
I just had an oil change done and the tanks are full. Fuel pressure is good. The engine isn’t getting hot enough. I have a cheap glow plug relay on there. I think I’m not getting enough amps through it. So I ordered a new one.
Old Jan 27, 2022 | 01:42 PM
BuddyBarnes's Avatar
BuddyBarnes
When you turn the key on how long do you wait to start the engine? Don't try as soon as the wait to start light goes out, give it a full min
Cheap relay? Cheap glow plugs too? I may have missed something in reading.
Old Jan 27, 2022 | 06:53 PM
Patriot381's Avatar
Patriot381
I wait until the “wait to start” light goes off and an additional 20 seconds after that before starting. My glow plug kit and harness was a kit that came with a relay and it was around $350. It’s supposedly motorcraft set.
Old Feb 22, 2022 | 07:51 AM
Patriot381's Avatar
Patriot381
Now getting Code P0713.
Just wanted to give an update. The IPR o-ring blew out and had to get a rebuild o-ring kit for it. Truck is now running, but has a bad shake. Drove it to the end of the driveway and white smoke coming out of exhaust. Had to replace glow plugs again, three were swollen at the tip. Pulled it back into the shop and let it sit overnight. Checked all the oil and fluid levels. Got new injectors on the way. Hoping this is the last of the problems.
Old Feb 22, 2022 | 08:07 AM
Patriot381's Avatar
Patriot381
Video attached.
File Type: mov
flatbedpower
Nov 11, 2013 05:05 PM
qadash
26
May 14, 2012 12:48 PM
blackdakotadave
29
Jan 17, 2012 07:16 PM
dand24u
18
Apr 8, 2009 11:13 AM
seanlleiker
Feb 6, 2007 07:07 PM
