Dome light troubles
Old Jan 23, 2022 | 05:24 PM
j_cooper5's Avatar
j_cooper5
Dome light troubles
Hey yall I've got a 94 f150 and I just put in a new universal socket in the dome light because the old one was burnt up. Anytime I put a bulb in the new one it blows the fuse as soon as I open the door. Any ideas what's going on or how to fix it?
Old Jan 24, 2022 | 11:26 AM
wwhite's Avatar
wwhite
What part did you buy?
What was wrong with the original?
Basically, you probably have a direct short to ground, meaning the power feed from the fuse box to the light bulb is shorted to ground.
This could be a problem at the bulb socket, or a pinched wire.
You can determine if it is wiring or the new socket or incorrect bulb:
- unhook positive wire from socket, remove light bulb.
- insert new fuse.
- use volt meter,
- open door
What is the voltage? If you have voltage, good. No voltage, wire is the issue.
Does fuse blow? If the fuse does not blow, good. Blown fuse, wire is shorted.
Does the fuse still blow with no light bulb in socket?
Is the universal socket connected correctly?
With the wires disconnected, test for connectivity on the sockets metal area or gournd and the positive wire.
If you have connectivity, the socket is shorted out.
Kevin Syler
May 16, 2019 09:37 PM
Brian085
30
Sep 15, 2011 07:18 PM
JohnT
Nov 20, 2004 10:03 AM
nickh829
Electrical Systems/Wiring
Nov 15, 2004 02:06 PM
