1995 E150 transmission problem
Old Jan 22, 2022 | 01:24 PM
Cobraconversion's Avatar
Cobraconversion
I have a 1995 E150 conversion van that ran fabulously until the battery was dead and had to be jumped. After that it needed a new ECM. It sat for a year during this time. After that the speed control sensor had to be replaced and it began shifting erratically intermittently. It may not have a problem for 2-6 hours then start shifting hard or not shift into second. Then park overnight and it may be fine again the next day. After several days of driving it seems to have more problems. Then it will be fine after sitting several days.
I love this old van. I have had it to the ford dealer. Who thought they had it fixed but then after a long drive it started up again.
Any ideas?
Old Jan 23, 2022 | 07:21 AM
JWA's Avatar
JWA
Take it back to the dealer and demand they take another look OR refund you money, find a competent transmission shop to diagnose the issues.
This could all be related to the replaced ECM.
Old Jan 23, 2022 | 08:21 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What is a speed control sensor? I'm not familiar with that term.
Whatever it is, it sure seems like the new sensor is the problem. If I am reading this right the problem started when that sensor was replaced.
Old Jan 23, 2022 | 12:48 PM
Cobraconversion
The speed sensor was replaced because the ecm threw a speed sensor code. The check engine light has not come back on since the new ecm was installed. Then the van was driven over 6 hours only stopping for gas before the transmission started acting funny again. Would the transmission be going bad and run smoothly for that long?
No it was acting up before the sensor was changed.
Old Jan 23, 2022 | 03:18 PM
Mark Kovalsky
Are there any codes stored?
What speed sensor code was set? What speed sensor was changed? I've never heard of a speed control sensor.
Mikel350
Apr 15, 2018 11:23 PM
daredevil95
Modular V8 (4.6L, 5.4L)
Sep 27, 2012 07:16 AM
nalts
Sep 18, 2010 07:15 AM
frogman
1997 - 2003 F150
Dec 9, 2000 08:10 PM
billtruker
1997 - 2003 F150
Oct 1, 2000 12:22 AM
