Electrical issues/possible loose ground
Old Jan 20, 2022 | 12:47 PM
RigCity's Avatar
RigCity
Below is a photo of the current codes for the most part they indicate a open ground /short. Not sure what steps to take next. The airbag light is not activated on the dash nor abs. Truck seems to operate as usual. Just did a cold start at 25 degrees and there were no issues. Was tough to start the other day after sitting for a week seems to be loosing power if left to rest.
Thanks for the help
U1059
U1262
B1352
B1921
C1095
Old Jan 20, 2022 | 12:52 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Just so we are clear, what manufacturer year vehicle were these codes pulled from? It does make a difference when selecting pinpoint tests for auxiliary systems.
Old Jan 20, 2022 | 02:31 PM
RigCity's Avatar
RigCity
The truck is an 02
Old Jan 20, 2022 | 03:09 PM
Sous's Avatar
Sous
FTE Emeritus
I am not seeing those DTC's in the manual. I have been looking and come close to them, but not specifically those DTC's. The sections for the trucks with a VSM instead of a GEM are a lot more convoluted in my opinion when looking at the manual.
I would encourage you to select the DTC's within FSL and/or search for them on the interwebs in order to narrow a section of the vehicle to look at.
If you suspect a ground is bad or loose, check the major grounds like the 2 on the block, one above the PCM on the firewall, one near the hydroboost on the fender, etc... I apologize I could not be of more specific help to you.
Old Jan 20, 2022 | 06:34 PM
Ed in Maine's Avatar
Ed in Maine
My 02 had a loose ground on the front of the block down low where the fuel lines start to come up. It is hard to see/tighten, but it was oil covered and hand tight. I was not having any issues, just passing it along.
Old Jan 20, 2022 | 09:34 PM
FordTruckNoob's Avatar
FordTruckNoob
I was able to find U1059 in the Instrument Cluster section of the manual. Attached is a PDF of that entire section of the manual. You will need to perform Pinpoint Tests F.
The rest of the codes are found under Multifunction Electronic Control Modules. Follow the document's guidance on the pinpoint tests to perform for each code accordingly.
File Type: pdf
cpobst
Jun 5, 2023 06:04 PM
Rafael Velazquez
3.8 & 4.2L V6
Aug 16, 2017 06:32 PM
droptop351
Jul 4, 2016 09:15 PM
Lynch02
1983 - 2012 Ranger & B-Series
Oct 10, 2006 11:46 AM
