2008 E450 Pats Light Blinking NO start ** SOLVED **
Old Jul 4, 2016 | 03:21 PM
droptop351's Avatar
droptop351
I have a RV on a 2008 e450 chassis. When you go to start it the pats light blinks really fast. Sometimes I can get it to start by opening closing doors turning ignition on and off havent found one pattern that works.
Im supposed to leave to take family on vacation tomorrow and im fighting this. Any help is appreciated greatly.
This is not a pats equipped vehicle it has just hte plain jane keys.
Ive tried changing battery to no avail.
Tried leaving cable off battery to let it reset
Tried pats reset procedure (figured was worth a try)
Symptoms:
1.) no start
2.) sometimes gauges go flat and odometer will read --------
3.) sometimes odometer will go blank
4.) abs and airbag lights come on from time to time
5.) when I come to stop at a light 4 lights will come on in bottom left and immediately go away when i start driving
Turns out that the fuse box under the dash was dangling and this caused all of the problems.
Old Jul 4, 2016 | 03:22 PM
droptop351's Avatar
droptop351
Friend of mine seems to think its a bad speedo and or ecm.
Old Jul 4, 2016 | 03:54 PM
VintageDave393's Avatar
VintageDave393
All of those symptoms point toward an issue with the PCM (computer), which is probably related to a bad ground or corrosion.
First thing to check is ALL of the grounds. The fact that you can get it to work after opening/closing the doors also points toward a loose ground somewhere. The vibration is probably giving you an intermittent ground.
Old Jul 4, 2016 | 09:15 PM
droptop351's Avatar
droptop351
i went so far as to put another ground from battery to fender just to try and got same result.
I also found that its blinking a 1-6 pats code
Davidg1567
Escape & Escape Hybrid
Aug 20, 2014 10:50 AM
endobear
Apr 18, 2013 11:25 AM
herojeep
Feb 1, 2012 09:33 PM
TriumphTruck
2004 - 2008 F150
Dec 19, 2010 12:08 PM
RebelT
1997 - 2003 F150
Mar 18, 2010 11:49 AM
