Sponsored by: Real Truck
No response from accelerator petal
Old Jan 18, 2022 | 01:36 PM
natemc08's Avatar
natemc08
A few days ago Going down the highway my petal stopped working and threw a engine light i let off the throttle and it started working again I was using a chip tuner at the time and removed it that night thinking that was the issue but the next day I had no throttle except for in park or neutral and when I did have a petal in drive it was constantly Reving or going back to idle I’ve replaced the accelerator petal with a OEM one from ford I’ve swapped the Idm and the transmission harness with no luck and I’ve checked all my fuses anyone else have any ideas?
Old Jan 18, 2022 | 02:45 PM
bwguardian's Avatar
bwguardian
It would be good to know what vehicle and engine combo we're trying to diagnose. When you swapped the accelerator pedal out, what part exactly? There's an electric sender that's probably your issue up where the pedal is...
Old Jan 18, 2022 | 03:27 PM
natemc08's Avatar
natemc08
it’s a 2002 f250 7.3 with the stock automatic transmission the petal and sensor are built together so the whole petal assembly with the ivc and the app sensor are both new from ford not sure of the exact part number but I can get it if needed
Old Jan 18, 2022 | 03:53 PM
bwguardian's Avatar
bwguardian
That's interesting as if I remember correctly, that sensor could be bought and replaced separately, and I've seen them be bad out of the box...
Old Jan 18, 2022 | 04:42 PM
natemc08's Avatar
natemc08
I’ve read they can be but I didn’t see a way to remove it I attempted to replace it with the one from my 2001 but they changed the pedal assembly from 2 plugs to one 5 prong plug
Old Jan 18, 2022 | 07:11 PM
natemc08's Avatar
natemc08
I did some looking and tapped my fender well and my truck shut down. I wiggled the pcm harness and the truck skipped and died so I’m thinking that may be my issue
Old Jan 18, 2022 | 07:23 PM
bwguardian's Avatar
bwguardian
Fender well points to the IDM...do you have Forscan to diagnose?
Old Jan 19, 2022 | 09:45 AM
natemc08's Avatar
natemc08
I do not but shaking the IDM harness does nothing until I move the pcm harness
randymacbc
26
Dec 31, 2019 12:25 PM
admorris
2004 - 2008 F150
28
Apr 22, 2015 12:25 PM
aprice
Oct 17, 2011 08:59 PM
stangman516
Dec 23, 2008 11:15 AM
AWM
Computer Chips & Tuners
Apr 9, 2003 10:41 PM
