2017 Fuel filter
Old Jan 17, 2022 | 08:56 PM
gatorlife1's Avatar
gatorlife1
2017 Fuel filter
Hey all… have a 2017 f250 6.7 diesel and want to change out the fuel filters. It says the underneath filter by the fuel cell must disconnect the hose above the filter on the 2017 (not need for 2018+) Which is this? I have a couple blue clamps above and a yellow to the side rail… I saw a video where they said you don’t have to do this, so tried draining and after 6 gallons of my 3/4 full tank came out without slowing down, i stopped the process and I believe this probably is actually needed to disconnect…can someone help? Even some pics? Thanks.
Old Jan 17, 2022 | 09:56 PM
Norcalpr's Avatar
Norcalpr
I dont do this, but I also do my fuel filters with half a tank or so.
You'll get a little over half a gallon out of the system. I usually drain that one and start on the engine filter while it's draining.
Old Jan 18, 2022 | 04:08 AM
harmanrk's Avatar
harmanrk
It sounds like you have a 2017 Job 1 truck. They were really bad about syphoning the tank with changing the fuel filter. As Norcalpr said, only do this with low fuel in the tank (helps break the syphon) or remove the fuel line as directed. My 2017 Job 2 truck does not do this when changing the filter, but I have only change it with about a quarter of a tank
Old Jan 18, 2022 | 07:20 AM
gatorlife1's Avatar
gatorlife1
Thanks! It definitely seemed like siphoning, got real low drain then became strong drain with a siphon sound in tank. It was 3/4 full so will attempt again on lower tank level. Appreciate the input.
Old Jan 18, 2022 | 07:27 AM
redford's Avatar
redford
FTE Leadership Emeritus
That'd be handy if you ever need to drain the tank.
Old Jan 18, 2022 | 08:10 AM
B-ManFX4's Avatar
B-ManFX4
Having less than a 1/4 tank and pulling the front end up on ramps will help with access and to stop the siphon effect.
mxer0022
Dec 17, 2024 11:20 AM
Qwazert
6.2L V8
Oct 26, 2024 09:17 PM
stevestroke01
Jun 27, 2011 10:38 AM
61 uni
Nov 22, 2008 08:20 AM
