Pcm Questions
Old Jan 16, 2022 | 09:38 PM
JamesKing41's Avatar
JamesKing41
Pcm Questions
I bought a obs 7.3 psd off fb. Looking to do an idi to psd swap. Good looking motor. But the guy gave me what he thought was the right pcm, I didn’t know at the time but it’s a DAC2 out of a superduty. Do I need to buy a new pcm or can I use this one. I know superdutys are split shot but idk when they went to that. The psd I got was a 96, so it’s a later year if that helps any.
any advice helps 🙏
much love
Old Jan 16, 2022 | 10:02 PM
JamesKing41
It doesn’t have injectors, reading some more I noticed the 96 had or has split shot injectors? But not 100% does it matter if I buy split shot injectors, if the pcm requires it. Or a whole new pcm (MIF series is what I’ve read so far) DAC 2 DPC412 from the 99 sd psd is what google says I’ve got
Old Jan 16, 2022 | 10:20 PM
96 OBS's Avatar
96 OBS
Your 96 does not have split shots. I think it should work I’ve heard of people using them. Might need a custom tune to run with the single shots but that would probably be the extent of what you need. That’s my take on it anyway but someone who might know better or possibly have done it will chime in here
Old Jan 17, 2022 | 09:57 AM
BuddyBarnes's Avatar
BuddyBarnes
IIRC there is a difference in wiring to the pcm on the 99 up verses 94- 97. Not sure .
JamesKing41
Jan 17, 2022 12:48 PM
Rabbid
WTB - Parts & other
Aug 21, 2012 04:01 PM
thechad
Jul 27, 2004 09:18 AM
