Weak fuel pump?
Old Jan 16, 2022 | 05:14 PM
Hootr's Avatar
Hootr
Weak fuel pump?
I think my fuel pump may be tired. Just seeing what you guys think
My fuel pressure is dropping under load empty. When climbing a 6% grade on hwy, pressure was dropping to 40-45 psi.
Did a little test on it today
Idle
Pre filter - 58 psi
Post filter - 54 psi
Taking off normally from red light
Pre filter - 54 psi
Post filter - 50 psi
Stepping on it passing on hwy
pre filter - 50
Post filter - 40
Haven't looked at fuel filter yet
Got about 10-12k on this fuel filter. Ordered a couple more. Was pretty clean last time I changed it.
With a clean filter, does any one know what the psi drop should be between pre and post filter?
Thanks
Old Jan 16, 2022 | 06:03 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Increase your pressure to 75 psi.
Old Jan 16, 2022 | 06:12 PM
kbeefy's Avatar
kbeefy
Do the regulator spring mod. Forgot what it's called.
Old Jan 16, 2022 | 06:17 PM
jstihl's Avatar
jstihl
Sounds like your filter might need changed, check to make sure it's not black. I have a slight injector o ring leak which is turning my filter black and clogging it up. Was experiencing same issues as you but after a filter change it helped out the fuel pressure drop under heavy load. Another issue might be your in tank pick up screens if you haven't done the hutch mod yet. Start with the easy stuff first
Old Jan 16, 2022 | 06:20 PM
timmyboy76's Avatar
timmyboy76
Mine went/got weak last year but, it would drop to 0psi climbing a hill..had to pull over and let it build pressure to get home...4hr drive to do 90 miles from Barstow to Yucaipa lol
Old Jan 16, 2022 | 06:47 PM
Hootr's Avatar
Hootr
Thanks for the replys.
I have Riff Raffs FPR with the gold spring, Hutch/Harpoon also done w/ racor on frame. Really no air bubbles in racor at idle
I haven't checked fuel filter yet, was just going to wait for the new filters to come in and just change it . Anyone know pressure drop from pre to post?.
I guess I could also try the black spring for the FPR,
So it sounds like no one think it's the pump. Since truck was empty, and I saw it dropping that much, I thought it would be the pump.
Old Jan 16, 2022 | 07:22 PM
RacinJasonWV's Avatar
RacinJasonWV
Considering your other mods, no bubbles in the Racor, and already having the gold spring I think it could be the pump.
The low pressure is a new development correct?
Old Jan 16, 2022 | 07:50 PM
timmyboy76's Avatar
timmyboy76
Somehow, crap got passed by the inline filter, clogging up the pump inlet..figuring, it worked hard and compromised its life, I obligated to toss a new 1 in
Old Jan 16, 2022 | 08:21 PM
Wes444's Avatar
Wes444
If your pre filter pressure is low like that I'd drop in the middle strength FRx spring before replacing the pump.
Old Jan 16, 2022 | 08:47 PM
Easy Eddy's Avatar
Easy Eddy
What's the temperature right now where you live? If it's below freezing, are you using anti-gel additive?
I had a very similar problem that behaved much like missing at high rpms and the anti-gel additive took care of it.
Old Jan 17, 2022 | 07:53 AM
Hootr's Avatar
Hootr
I have the middle spring in it. Gold 62 psi. The black spring would be 70 psi
I am running Hot Shot Secret anti-gel when I filled up a couple weeks ago.
I have very little crap at the bottom of the racor although it's possible.
Going to try and replace fuel filter 1st.
Are there any other tests on the fuel pump I can try?
Old Jan 17, 2022 | 08:14 AM
timmyboy76's Avatar
timmyboy76
Coffee hasn't kicked in yet but only thing that comes to mind is, remove inlet hose to pump, and inspect the pump spigot...thats where the crap was built up on mine(after I'd already removed pump)....
if nothing there then I'd change bowl filter and hit the pavement, checking pressure at various throttle positions
Old Jan 17, 2022 | 10:53 AM
Kwikkordead's Avatar
Kwikkordead
What's been mentioned multiple times already in this thread, check the inlet of the pump. There is a screen inside that get's clogged. No good way to clean it thoroughly. There needs to be a replaceable cartridge filter between the tank sump and the fuel pump, IMO. Raising the fuel pressure will do nothing to alleviate the problem. What you are dealing with is lack of fuel VOLUME not pressure under load. Need to get that fixed and you'll have your truck back.
Old Jan 17, 2022 | 03:38 PM
F250_'s Avatar
F250_
Can also remove the inlet line to the fuel pump (suction side), and blow backwards through that line into the tank. If your pickup foot has crumbled or if you've gotten trash in the tank, it can get caught up at either the inlet to the pickup tube itself, or in the 90° bend coming out of the top of the tank. If you get good airflow blowing through the line into the tank, you'll hear the aggressive gurgling when you do this and then you'll know the line is open.
If the above resolves your issue, then plan to run the tank down near empty, drop it, and then clean out the tank and replace the plastic pickup foot (if you're still running one).
bflora
28
Mar 26, 2014 06:01 PM
grec-o-face
May 23, 2013 05:31 AM
JOHNSHO
Oct 11, 2011 05:56 PM
DSMMH
Feb 25, 2010 12:23 PM
JustinSWeber
13
Aug 28, 2008 11:51 AM
