2017+ Trailer Brake Controller
Old Jan 16, 2022 | 05:04 PM
Iraqvet88's Avatar
Iraqvet88
This may be covered elsewhere but I cannot find anything that matches my issues exactly.
On two separate trailers I am having a “No trailer connected” message when actuating the brake controller. When you hook up the trailer it says trailer connected and all lights work properly. Checked all fuses in cab and under hood called out by association in the manual. Checked and greased all connections under the bed and in the bumper. Replaced the 7 way truck side connector and still no change. With trailer 7 way connected to the truck and no other physical contact between truck or trailer I am getting good continuity from truck frame to trailer frame so I know I am getting a good ground outside of the hitch.
Truck came stock with the trailer package, double checked forscan that nothing had been changed accidentally. Checked all other modules as well against the as-built data. While in forscan I also ran self tests on theIPC and trailer control module and everything passed. Am I missing something simple? It doesn’t make sense that everything works beside the brakes. If it were only on one trailer I would suspect the towed brake system but it happens on all trailers.
2018 F-250 XLT CCSB 6.7L
Old Jan 16, 2022 | 09:17 PM
jdnariz's Avatar
jdnariz
The connector is temporarily losing connection. Coat the make pins with dielectric grease.
Old Jan 16, 2022 | 10:06 PM
Joe T's Avatar
Joe T
I ziptied my 2013 connectors on the truck tight. Clip was broken behind the 7way.
Did the exact same thing.
Old Jan 17, 2022 | 04:05 AM
B-ManFX4's Avatar
B-ManFX4
Check the battery for the break-away circuit on the trailers. 10 - 1 it is dead. Bypass the battery as a test and I bet your brakes work without the error message. Ask me how I know this...
Old Jan 17, 2022 | 11:58 AM
Iraqvet88's Avatar
Iraqvet88
@jdnariz
Thank you for your response. If you hadn't seen in the original post, every connector has been pulled apart, cleaned and greased.
@Joe T
Thank you for your response as well. The 7 way connector on the truck side has also been replaced also as stated.
@B-ManFX4
I'll try that this evening but it would not explain why I have had this issue on two separate trailers.
Old Jan 17, 2022 | 01:05 PM
Marcm15's Avatar
Marcm15
This is likely the cause of your problem - It has been identified by several others as well....
Old Jan 17, 2022 | 02:38 PM
B-ManFX4's Avatar
B-ManFX4
Originally Posted by Iraqvet88
@B-ManFX4
Are you saying both trailers can't have bad batteries? If they are not used fairly frequently with trucks that are re-charging them properly I can almost guarantee they are both bad.
Rizzy
All Things Towing
Dec 3, 2020 08:09 AM
DGMFORD
Sep 30, 2020 08:59 PM
Michael53
6.7L Power Stroke Diesel
13
Feb 25, 2015 05:51 PM
phantomphixer
All Things Towing
34
Jan 17, 2013 09:27 PM
dixoncity
23
Aug 30, 2011 09:22 PM
