Truespeed module problems
Old Nov 5, 2003 | 01:14 PM
Duksrule's Avatar
Duksrule
Read my post "OKProfanity Removedhappened to my truck" and you will see what problems I was having. Service department pulled the fuse to the truespeed module and now the truck will run. I called Superlift and they said that the 6.0 is not an application for that module and that I should remove it.
It ran fine for over 2K miles with the module in. This doesn't make sence to me. Anyone have any troubles with the Truespeed on a 6.0???
Old Nov 5, 2003 | 02:07 PM
Hjudge49's Avatar
Hjudge49
What's it supposed to do? And how do we find out if we have one?
Old Nov 5, 2003 | 04:55 PM
Duksrule's Avatar
Duksrule
Truespeed is a module that is made by Superlift. It is used to correct the speedo for bigger tires. If you haven't put one on chances are that you don't have one.
Old Nov 6, 2003 | 05:59 AM
Daha's Avatar
Daha
Duksrule,
I am interested in this also as I will be running 285/70R on 19.5" rims and they recommend I buy the TruSpeed Calibrator.....
Here is a link to the item: TruSpeed
So, can the dealer reprogram for larger tires/rims???
Old Nov 6, 2003 | 06:16 AM
Duksrule's Avatar
Duksrule
I am just going by what I know from what has happened to me. I got my truck home and took out the truespeed module and it runs fine. I mentioned in the other thread that when I called Superlift tech support they said not to run the truespeed module with the 6.0 because they didn't design it for the 6.0 and there may be trouble. I found the trouble first hand.
I hear that the dealer can recalibrate for tires up to 35s. Not sure though. I am going to call today and find out though. Even if I can get reprogrammed for 35s that will be close enough for the 37s I am running.
jimd1050
6.4L Power Stroke Diesel
Dec 20, 2011 01:55 PM
Nikolai
Jan 26, 2008 06:04 PM
texcan
Jun 17, 2006 11:17 AM
heidiandmax
May 21, 2005 10:26 PM
ROKNZRX
Mar 23, 2005 07:25 PM
