Sponsored by: Real Truck
Customer access wire for truespeed use ?
Old May 21, 2005 | 06:16 PM
heidiandmax's Avatar
heidiandmax
Has anyone used these access wires for use with the Superlift Truespeed Module ?I am looking for the easiest way to run the green & yellow from the truespeed into the engine compartment of my 01 f250.Also what are some of ways everyone ran thier truespeed.Any and all information is appreciated.
Thanks in advanced.
Old May 21, 2005 | 06:25 PM
MARZ06's Avatar
MARZ06
You don't need the access wires. Use the fuse tapper for power and the ground location is on the right (existing). I ran the yellow/green wire through the firewall via an existing hole that is on the drivers side. I tapped the VSS signal wire at the ABS module, per the instructions. Others have found the same wire under the dash...wish i had known it was there, would have been much easier.
Old May 21, 2005 | 06:48 PM
heidiandmax
Allright, I am going to look again.Where excactly should I be looking?
Old May 21, 2005 | 08:46 PM
firesoutmatt's Avatar
firesoutmatt
The abs wire is under the drivers side battery and airbox. It easier to get at if you drop the drivers iner fender well and follow the instructions on which wire it is. Make sure you use good wire splices and seal them from water. I used permatex silcone and sealed both ends . Then use a GPS or the mile markers and get it dailed in.
Good Luck
Old May 21, 2005 | 09:34 PM
MARZ06's Avatar
MARZ06
He has a V10....need to remove the air filter assembly and vapor canister only. It's definitely easier to access the ABS through the fender well.
Old May 21, 2005 | 10:26 PM
heidiandmax
I ran the wire thru the firewall via the existing hole(thanks marz) behind the flap in the mat,all the way down to the ABS unit.Going thru the fender well seems to the easiest route will finnish in the morning.Thanks marz & firesout.
texcan
Jun 17, 2006 11:17 AM
ROKNZRX
Mar 23, 2005 07:25 PM
icyford
Apr 12, 2004 10:47 PM
offroadjunkiex
Jan 18, 2004 08:41 PM
Duksrule
Nov 6, 2003 06:16 AM
