ignition switch not cranking starter
Old Jan 15, 2022 | 05:18 PM
pendey's Avatar
pendey
Question ignition switch not cranking starter
hello everyone,Im new to the site so ill explain my delima.I purchased a 1976 f150 4 wheel drive years ago.It wasin the middle of a ground up restoration.Ive re installed the wiring harness under the hood,i have power to headlights,wipers and heater.However im not getting signal to my starter from the ignition..Ive checked all grounds and even added a couple, still the same issue.can someone point me in the right direction.Its been years in the making to get this truck to crank over.ITdoes crank if i crossover the solenoid.thanks for any help.
Old Jan 15, 2022 | 08:05 PM
dlburch's Avatar
dlburch
do yo have 12v at the I connection on the solenoid? if so, your solenoid is either bad or not grounded.
is the wiring connected to your neutral start/reverse light switch under the dash on the steering column?
Old Jan 16, 2022 | 08:45 PM
Ozzie H.'s Avatar
Ozzie H.
If it is determined that you need to replace the solenoid.................be careful. Some of the replacements are sad; others are better. Try to get a better one.
Old Jan 17, 2022 | 11:50 AM
kegger66's Avatar
kegger66
x2 on suspect solenoid and replacement- I spent the couple extra bucks to get a motorcraft solenoid so I don't have to worry about it.
Old Jan 17, 2022 | 12:43 PM
meangreen92's Avatar
meangreen92
Make sure you're getting 12V+ from the trigger wire, the one which pushes onto its solenoid terminal, and make sure it's pushed onto the correct small post. Solenoid should be marked for S (starter) and I (ignition). You want S.
Old Jan 20, 2022 | 06:18 PM
pendey's Avatar
pendey
thanks for info guys,let me back track some on my post..when this truck was getting the start of its complete rebuild at least 2 trucks were being used.I used the harness that came with the truck.So i guess my question is ,do i need to try using different harness.I have power at coil and starter solenoid,however the ignition switch will not crank the motor.It does crank over when i cross over at solenoid.alsocan someone tell me what the green box style plugs are used for coming from the inside of cab to the engine bay by the ignition control module.?thanks for input
Old Jan 20, 2022 | 07:36 PM
dlburch's Avatar
dlburch
can you clarify what you mean by having power at the solenoid? do you mean power on the I terminal with the key in crank position?
and when you say crossover at solenoid, do you mean shorting the two large lugs, or shorting between the front battery terminal and the smaller I terminal?
I assume your solenoid is mounted tightly to the fender and has a good ground?
Old Jan 20, 2022 | 09:28 PM
1browski's Avatar
1browski
If the plugs you are referring to are squarish 4 wire plugs, it is probably the lights. I think there would probably be 3 of them. If its the lights, there will be three of the same on the other side. Pictures work great. Im getting ready to put my wiring harness back in my 72 f250. I did check continuity on everything. Figured I should do that at least. Good luck.
Old Jan 23, 2022 | 11:34 AM
pendey's Avatar
pendey
im trying to figure it out again today.My sloenoid is grounded well,motor turns over when i cross the solenoid over using a piece of wire.As far as testing the (i) terminal and the(s) terminal on solenoid ,my test light shows power .as well as testing at the coil..thi as been done with the key in on position..im trying to finish this truck.Which was torn down about 20 years ago by someone else.and he was using 2 or 3 trucks to rebuild this one..iltry uploading pics of the green plugs that are located in engine bay that arent connected to the harness in any way.Thanks for all input.with some help this thing will start using the key.l
Old Jan 23, 2022 | 12:04 PM
meangreen92
You can test for power at the small red wire, the one which plugs onto the S terminal post, and it should only have power when the key is turned to crank the starter. My guess is that it won't. Luckily, the wiring in these trucks is mostly easy enough to access, that you can probably trace it back into the cab without too much trouble.
The I terminal is only used for powering the ignition coil at the full 12V, while the starter cranks. And the I terminal should only have power when the S terminal is receiving power and powering the starter.
misterfisher
Apr 5, 2017 09:01 AM
79FORD-DENT
Feb 5, 2011 12:37 AM
silver9696
Jun 27, 2010 12:30 AM
txmnjim
25
Nov 16, 2009 09:17 PM
mommyof2
Illinois Chapter
Jun 15, 2007 02:01 PM
