Sponsored by: Real Truck
greaseing
Old Jan 14, 2022 | 10:21 PM
Kalani808$'s Avatar
Kalani808$
Trailering
greaseing
OK everyone, I got a 2005 F250 Super Duty Harley edition. I was trying to grease the chassis like ball joints upper and lower, etc. I feel really dumb because I can't find any grease nipples where they're supposed to be. I can't grease any of the bushings because no nipples to connect grease gun to? Let me tell you guys how hard it was for me to say I can't find the nipples. Please help.
Old Jan 15, 2022 | 07:40 AM
AACoPD05's Avatar
AACoPD05
You may not have the nipples, zerk fittings. I believe there were some "lubed for life" ball joints installed on these trucks, I found this out when replacing my ball joints. I installed Motorcraft ball joints that had the fittings for grease when I replaced my worn out old ones, now I grease every oil change.
Old Jan 15, 2022 | 01:35 PM
Rudiak's Avatar
Rudiak
The only zerks on my 2008 SD are front axle u-joints (2).
Old Jan 15, 2022 | 05:37 PM
greg_23805's Avatar
greg_23805
Permanent Lubed fittings
This is true, auto manufacturers use lots of permanently lubed components for suspension, steering, u-joints on the drive axle etc. Not uncommon
Old Jan 15, 2022 | 05:54 PM
Kalani808$'s Avatar
Kalani808$
Trailering
Thanks everyone for your input. I always had older model trucks where grease was the prat of owning a truck. After more research found out a lot of trucks are like that, I guess I was just thought old school. Not sure if I like it I might just change it back to grease fittings and go from there.
Again, thanks everyone. Aloha
lbrowne
Sep 21, 2011 01:22 PM
BLADE35
Jul 16, 2011 10:36 AM
Toreador_Diesel
May 14, 2010 07:27 PM
JDiesel450
Feb 10, 2010 09:44 PM
oldnavy638
Feb 9, 2005 08:50 AM
