Sponsored by: Real Truck
grease points
Old Feb 7, 2005 | 08:45 PM
oldnavy638's Avatar
oldnavy638
grease points
I have an 02 F250 and wanted to know if there is any site or if anyone could tell me where all the grease points are?? Thanks
Old Feb 7, 2005 | 10:36 PM
wyomingfisherman's Avatar
wyomingfisherman
I've got an '02 F250 SD as well. I've not been under the vehicle to check it out as I've only had it for a month, but my Haynes manual reads they are on the balljoints, tie-rod ends and universal joints. They caution that there may be plugs installed in these areas, which will require the purchase of the grease zirk fittings at a parts store. Remove the plug and install the fittings, if you find any.
Old Feb 7, 2005 | 10:45 PM
SMiller's Avatar
SMiller
I don't think the stock ball joints have grease zerks as well as the stock U-joints, none of the U-joints on my SD are greaseable, my ball joints have been replaced and are now greaseable, I think there are about 5 grease zerks on my truck, I like to maintain my stuff and wish there were grease zerks on everything since I often grease everything that there is to grease.
Old Feb 7, 2005 | 10:49 PM
KitsKid's Avatar
KitsKid
Old oilfield saying, "If it moves, grease it. If it don't move paint it." That's my motto. I can't tell you how many grease zerks are on your truck but if it is like most that I find, not near enough, nuff said.
Old Feb 7, 2005 | 10:50 PM
oldnavy638's Avatar
oldnavy638
ya thats my problem too. I am used to greasing my dump trucks and machines and i have had my truck for almost a year now and i havent greased anything
Old Feb 9, 2005 | 06:15 AM
DZari's Avatar
DZari
I looked over my 05 SD and found only 2 zerks. One each on the outboard u-joints front axle.
Old Feb 9, 2005 | 08:45 AM
LOOnatic's Avatar
LOOnatic
I have a 04 4x2 and have 4 fittings in front.
Old Feb 9, 2005 | 08:50 AM
beemr's Avatar
beemr
...now why would they go to the trouble of putting plugs in place instead of the actual zerk? Material cost should be negligible.
