MOOG balljoint??????
Old Jul 15, 2011 | 02:09 PM
BLADE35's Avatar
BLADE35
hey guys
as some of you guys know I just put in moog balljoints both upper and lowers the truck steers GREAT and rides smooth.
Anyway I was just wondering about the grease fittings on the upper balljoint I greased them and then I pulled the grease zert out and installed the plug. I didnt want to chance the axel taking out the grease zert.
I found a grease zert that didnt hang down as far as the one that came with the moogs but its not too much shorter maybe an 1/8inch shorter so IDK
Is everyone just leaving the plug in untill it needs greasing or has anyone had any luck with a 90* grease zert that doesnt hit. The other one that I found clears when its just sitting there in the driveway Im just worried about taking it out going down the road
THANKS in advance Benny
Old Jul 15, 2011 | 02:14 PM
rocknut's Avatar
rocknut
I just greased mine up and put the plug in. there is not enough clearance for a fitting there. Or even with a flush mount type zerk fitting you can't get the grease gun on it using the needle style end.
Old Jul 15, 2011 | 03:10 PM
BobbyB's Avatar
BobbyB
I replaced my ball joints with the Moog ball joints also. I installed straight grease fittings in the upper ball joints and use a right angle grease coupler to grease them. I have no interference issues and don't have to remove the plugs at each greasing. I bought the right angle grease coupler at TSC. It works great!
Old Jul 15, 2011 | 08:22 PM
fmtrvt's Avatar
fmtrvt
And that was the design intent by Moog. Too many people have tried to put the 90° zerk up top.
Old Jul 15, 2011 | 09:40 PM
BLADE35's Avatar
BLADE35
thanks for the help guys
so if I have this straight instead of the 90* grease zert I put in a straight grease zert and then use a 90* on the grease gun
I would assume this grease zert a short one
Old Jul 16, 2011 | 07:46 AM
fmtrvt's Avatar
fmtrvt
Straight zerk up top and one of these to grease it:
Amazon.com: Lincoln Lubrication 5883 Slotted Right Angle 90 Degree Coupler: Automotive
While this is a link to Amazon many stores carry these, including farm suppliers.
Old Jul 16, 2011 | 10:36 AM
JESTERxHEAD's Avatar
JESTERxHEAD
just use a 90 deg. low height fitting and take it to the bench grinder and just kiss it on the back corner....tons of room now....I have had them in there for a couple years....and I use my 4x4 on a weekly basis.
