ECM
Old Jan 11, 2022 | 05:59 PM
Cade Cochran's Avatar
Cade Cochran
Trailering
ECM
I'm rebuilding my engine and running it on a different ECM. Is the transmission controlled from the stock computer on the truck?
Old Jan 11, 2022 | 07:20 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Is this for the 1990 in your profile? Yes, the engine and transmission control is all in the same computer. You haven’t said what transmission is in your truck or what computer you are planning on using.
Old Jan 12, 2022 | 07:08 AM
Cade Cochran
Trailering
I've not picked out a new ECM. I'm thinking about going with one from Holley, I want to keep it EFI. I haven't had a chance to see which trans it has yet. I think it is a E4OD.
Old Jan 12, 2022 | 07:39 AM
rla2005's Avatar
rla2005
Easy Button: Stinger Performance PiMP ECU's + Kits
If you have an E4OD it is the easiest solution out there. Even if you have an AOD it is still a very good product. Several folks on this forum are using them.
Old Jan 12, 2022 | 02:11 PM
My4Fordtrucks
The one that rla suggested retains the OEM system. You need to determine if you want to keep the stock EFI system or go with an aftermarket setup and still be able to control the transmission (if applicable).
Samsn4
Oct 25, 2013 06:42 PM
Rolait
Sep 17, 2010 02:00 PM
pepito113
2004 - 2008 F150
Jun 24, 2007 03:40 PM
meck1
Jul 25, 2004 08:49 PM
msautry
Nov 18, 2003 12:08 PM
