Carb info?
Old Jan 10, 2022 | 09:27 PM
Van Fink's Avatar
Van Fink
Carb info?
I have a 66 F100 that had been sitting for over 30 years. It wasn't hard to get it turning, little transmission fluid in the cylinders for a couple days. Cleaned the plugs, new points & fuel pump & it wants to run. I think the carb needs rebuilding. I'm not running from the gas tank because it's pretty rusty. My question is; is the information on the carb tag what I'll need to get a kit? Don't know if it's original or not. It says Motorcraft D2PF RA.. The tag on the engine says 352, I've known about the truck since it was new so I'm pretty sure the engine is original.
Thanks Van
Old Jan 11, 2022 | 12:45 PM
dubya TF's Avatar
dubya TF
Yes absolutely. If the truck has been sitting that long without running a rebuild certainly wouldn't hurt.
Old Jan 11, 2022 | 01:37 PM
g4g2g7's Avatar
g4g2g7
Thanks Van
That is the number you need for a rebuild kit. The original carb would be Autolite rather than Motorcraft - the motorcraft name wasn’t used until ~1972 if I remember correctly, so that carb was swapped onto the truck.
Google is your friend: took all of 30 seconds to search that carb tag number and find info.
Old Jan 11, 2022 | 06:26 PM
Van Fink's Avatar
Van Fink
OK, thanks. Now I know it's not the original, but that's not a problem. Napa has the kit ordered.
Binkowski
15
Feb 17, 2014 08:20 PM
Kazco
Oct 14, 2010 01:30 AM
camperspecial65
28
Aug 20, 2007 03:20 PM
rem8128
Jan 12, 2004 10:31 AM
keebler67
Nov 24, 2003 07:49 AM
