Need help
Old Jan 7, 2022 | 05:02 PM
SCAR3113's Avatar
SCAR3113
Trailering
Need help
I have a 1991 Ford F-150 started it this morning shut it off went to start it again and it would crank but couldn’t get it to turn over and now the only way to crank it is to jump the solenoid. When you turn the key to start it, it does nothing. Any help or recommendations would be helpful. Thank you.
Old Jan 8, 2022 | 07:49 AM
torq'ta 5 8's Avatar
torq'ta 5 8
check battery, with digital volt meter, it is getting to that cold part of the year, and you find out your battery was slowly dying, all summer, happens every year.
Old Jan 8, 2022 | 08:20 AM
rla2005's Avatar
rla2005
If you have an automatic transmission trying starting the truck in Neutral. If that does not work jiggle the shifter a bit with the key in the Start position. A mis-adjusted neutral safety switch (AOD) or MLPS (E4OD) will cause this issue. If you have a manual transmission check the clutch pedal interlock switch.
Old Jan 8, 2022 | 08:43 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Your other thread titled “ I need help” was about a broken steering column. This thread “Need help” is about a starting problem. Would you please start stating the issue in the thread title?
Old Jan 8, 2022 | 07:26 PM
torq'ta 5 8
'broken steering column'
Maybe he didnt get that fixed right?
Old Jan 8, 2022 | 08:15 PM
My4Fordtrucks
Maybe…
RECO6901
6.4L Power Stroke Diesel
17
Mar 9, 2025 06:21 PM
Blackjack8
Nov 11, 2017 09:33 PM
Josh Longmire
21
Jan 31, 2011 09:35 AM
Jesse Zimmerman
Aug 14, 2009 05:14 PM
earl964
Oct 1, 2008 05:40 PM
