Electrical issue
Old Jan 7, 2022 | 01:08 PM
netman's Avatar
netman
Electrical issue
On my 2013 w/5.0L At cold start up there are 3 warning messages. Hill descent control fault, power steering assist fail, service advace track system. The absence of power steering is the worst thing of coarse. 1st event had no choice but get to work on time. shut down and restarted after warming up driving it was fine. Have managed with it for several weeks. Lower morning temperatures are requiring too long of a warm up period. When it's mad there are no turn signals, or power steering with traction control/ABS or vehicle stability. haven't tested other controls on steering wheel etc. While out of state hunting a dealer suggested my steering column control module to be the issue but did not have one. So interesting that it performs normally above freezing. The old truck mechanic in me says moisture in a relay some where. Modern vehicle technician thinks a bad printed circuit board could be responsible for my new arm work out program. All advice is greatly appreciated thank you.
Old Jan 7, 2022 | 03:14 PM
RLXXI's Avatar
RLXXI
Need to know what codes are stored to begin diag but it sounds like a failed steering rack. It's electric not hydraulic.
Old Jan 7, 2022 | 05:00 PM
projectSHO89's Avatar
projectSHO89
Given that the scope of the symptoms is not limited to the EPAS system, it's probably something "upstream" from the rack.
Checking for codes is indeed the first step.
Old Jan 11, 2022 | 05:17 PM
Siberexpress's Avatar
Siberexpress
The Hill Descent and Service Advance Trac together with the EPAS fault are all together and it is normally just replace the rack like RLXXI said.
Northernroots122
19
Feb 1, 2024 04:49 PM
grog0x0
Jan 6, 2022 07:52 PM
rgh69
Apr 17, 2021 10:01 AM
2007FEH
Escape & Escape Hybrid
Jul 27, 2018 01:34 AM
brc777
2009 - 2014 F150
Mar 20, 2014 04:43 AM
