Electric Power Steering
Old Mar 19, 2014 | 03:38 PM
brc777's Avatar
brc777
Does anyone know if there has been any recalls involving the 2011 Ford F150 electric power steering.
Some info. A while back I made a post of how on a cold morning down here in the deap South (no -o weather), but below freezing. My girlfriend's 2011 Ford F150 steering wheel would not move. The weather got a little warmer that day and it finally would turn. But when she left for work again the next morning in below freezeing weather the steering would not turn again.
She has the 3.7L with electric power steering. After the steering wheel not moving incidents the steering started making a grinding noise. It sounded like it needed greasing. It has steadily got worse. I jacked it up and looked at it again this weekend. I noticed that the passenger side boot had a pretty big tear in it. Something I have never seen before. Could water have gotton in the boot causing the steering to freeze up on those cold mornings? Could not see where the tear in the boot had been slinging out grease or anything. Also after the steering froze up the "service advance track" would come on at random causing the blikers not to work.
Thought that maybe some recalls where made on the eps. Any advice would be appreciated.
brc
Old Mar 20, 2014 | 04:43 AM
brc777's Avatar
brc777
Can you buy just a component on the eps or do you have to replace the entire eps assembly. For example, if the eps power steering motor is bad can you replace just the motor or do you have to buy the entire assembly.
brc
brc777
2009 - 2014 F150
Feb 16, 2014 06:12 PM
GJCAT
Large Truck
Nov 23, 2013 12:12 AM
icovy
Dec 12, 2006 06:03 AM
dbhr
Offroad & 4x4
Aug 21, 2004 11:06 PM
