I usually hang out in the 48-56 F-100 forum but my SIL is rebuilding his 67 F100's 352. The Machine shop found a very small crack next to a intake valve seat. They think it will be OK but I'd sorta like to hear from you guys. Unfortunately I'm relaying this 2nd hand so I'm kinda at a loss for more specifics. I'm kinda leaning toward looking for a different head.
Your thoughts???
I had a set of C5? heads. Not exactly sure on the part number. They had what looked like a crack between the intake and exhaust valve. Turns out it was just in the casting and they ran fine. Since your info is second hand, maybe that's what it is and that's why they feel it's okay.
It was a long time ago, but I think we just looked at it with a magnifying glass. I have the heads off and next time I get a chance I''ll see if I can get a pic
That crack is not significant and very common, but it WILL definitely get worse with add'l heat / unleaded fuel. You can (patch) braze it but that really doesn't address the underlying problem (unleaded fuel).
The fix is hardened seats on the exhaust side and new valves---- plenty of machine shops will drill the counterbore, punch in new hardened seats to deal with modern fuels. This approach is THE permanent long term fix.
