Head mis-match
Wondering first if I have a problem with mis-matched heads. Left side is C6AE-6080-R (with a big 'R' also cast at back of head). Right side is D2TEAA with 203 3D cast at back of head.
According to the chart in Steve Christ book the D2TE is from 72-76 360/390/428 and has different combustion chamber volume than the C6AE that would appear to be original for the 352.
If I need to find a match to one of these, is either better than the other? I want to get it right before I spend $400-500 on new valves and hardened seats.
Any advice appreciated.
Jack
Yes, that C6 head is a bad mismatch to the D2 head. Sounds like one head was replaced a long time ago.
If it were me, and you're going for a valve job anyway, get another D2 head (or pair of D2s or C8s) from the junkyard and have them completely redone.
Question: Does the intake change from low-rise to high-rise head ports? If so, you might need a newer cast-iron 4bbl intake (or aftermarket) to match the D2/C8 heads, or find another C6AE-R head like you already have to keep the matched set matching the intake.
