High volume oil pump
Old Nov 5, 2003 | 08:09 AM
farlight7's Avatar
farlight7
Question High volume oil pump
Have heard two opinons about high vol. oil pumps.
My machanic told me to put a high vol pump in, even though I am putting in a crank kit (new main and rod bearings). He said the extra volume wont hurt.
Then I heard that a high vol and new bearings will cause seals to fail.
My engine is a 351w, 1990 efi stock.
Any ideas or personal experiences?
Thanks
Old Nov 5, 2003 | 08:41 AM
DanTana's Avatar
DanTana
There is no correlation between a high volume pump and bearing failure in a new engine. Sounds like an old wives tale to me. If your clearances are correct and everything assembled correctly you should have nothing to worry about. A high volume pump is deeper (longer gears) than a stock pump, so it can pump more oil per revolution to your engine.
Old Nov 5, 2003 | 09:15 AM
farlight7's Avatar
farlight7
OK, so it wont hurt the bearings,
but will it do any harm to the engine seals, like rear main, oil pan etc?
Old Nov 5, 2003 | 09:24 AM
DanTana's Avatar
DanTana
The only thing I've ever heard is if you get a high pressure/high volume pump that puts out somewhere over 100 psi then it "could" possibly blow out a seal. But I doubt if it is properly installaled if even then you would have an issue on a new engine. I've only heard that on older engines with suspect seals to begin with then you might get oil leaks, but a high volume pump alone will not cause any problems. Just be able to pump more oil to your engine.
Old Nov 5, 2003 | 09:28 AM
farlight7's Avatar
farlight7
Thanks
Old Nov 6, 2003 | 03:26 PM
JAY221's Avatar
JAY221
HIGH VOLUME OIL PUMP
The only thing I would add is to be careful with a high volume pump & stock pan. I have an 8 qt. Pan on mine & put 4 quarts of oil in it & primed it with a drill on the engine stand & I could pump enough oil to empty the pan. It wouldn't empty with 5 qts but that is to close for me. Just my experience for what it is worth. Later, Jay
Country705
Sep 11, 2016 04:53 PM
joogie22
31
Mar 21, 2015 09:15 AM
Vol56
New Member Introductions
Dec 18, 2013 08:30 PM
johaner78
Oct 10, 2005 07:36 PM
dsc
Mar 7, 2003 10:30 AM
