2003 excursion dome light
Old Jan 5, 2022 | 12:30 PM
bubba124's Avatar
bubba124
the front interior dome light stays on. All of the other interior lights go on and off when the doors are opened and closed and when using the dimmer switch. the door ajar light comes on when the doors are open and goes off when the doors are closed. the map lights work correctly when turning on and off.
thanks
Old Jan 6, 2022 | 06:31 AM
projectSHO89's Avatar
projectSHO89
The front interior dome lamp is wired in parallel with the rest of the interior (and exterior) courtesy lamp circuit. Unless the circuit has been modified, it is not logical for the front courtesy lamp to operate independently from the rest.
Is this a recently acquired truck that has done this since acquisition or did this behavior manifest during your ownership?
Old Jan 6, 2022 | 10:10 AM
DSMMH's Avatar
DSMMH
The interior lights “time delay” relay is probably bad. Swap with another relay and see what happens.
Ed
Old Jan 6, 2022 | 12:33 PM
projectSHO89
Ed
Not an possible endeavor. The relay is soldered into the instrument cluster's circuit board. Besides, it feeds ALL of the courtesy lamps in parallel as already noted so it can be ruled out.
Old Jan 7, 2022 | 02:25 PM
wpnaes's Avatar
wpnaes
A few of us just bypass the dome lights; handy when camping with kids who can't keep a door closed.
​​​​​​https://www.ford-trucks.com/forums/1...l#post12657576
Jetjock15
Nov 22, 2019 11:34 AM
levgoo
Jun 12, 2015 10:46 AM
chevma-67
May 16, 2014 02:02 PM
Pollydog
19
Sep 1, 2007 06:30 PM
