Sponsored by: Real Truck
Sync not hearing me
Old Jan 3, 2022 | 06:58 PM
Trevor Bouma's Avatar
Trevor Bouma
Sync not hearing me
2015 F250
Sync won't hear me no matter what. Every other functions works fine, but he Microphone does not hear me. Theres a never ending parts shortage at the moment and i cannot order a new Mic, but i did go to scrape yard and get a Mic out of a 2013 F150, that had three wires on it, (BT4T-19A291-AEW-39MC) plugged it in, and had the same results. this new mic had 3 wires instead of the two on my original but fit the plug just fine. My Microphone was working fine, even after a battery replacement but shortly after making some changes in Forscan, it lost touch with me.
I'm not sure if its an APIM issue, if its a Forscan issue, if its a Microphone Issue or exactly where to start. I'm mad enough that i'm thinking of just replacing everything with aftermarket components but even those are few and far between at this point.
Is there a way i can test this? Ive pulled fuses, master reset etc, but nothing has fixed it. Maybe i need to pull the fuse for longer, or disconnect the battery cables for longer.
What would you do?s
Old Jan 4, 2022 | 03:30 PM
Trevor Bouma
I wanted to update this thread, just so that if anybody else finds themselves in this situation they have something to try.
Background, when i first got the truck i played around inside of Forscan making some small adjustments and really just learning the layout. Despite my truck not having Navigation, i enabled the "Navigation while in motion" setting. My goal was to allow people to use my phone, pandora etc while in motion, or allow the passenger to pair their phone while i was driving etc. For whatever reason, i believe this also changed the Microphone type, cutting voltage off to the Mic i had. after sifting through the F150 Forums i stumbled into another guy having the same issue with an older F150.
Short story long, In forscan, under the APIM Module Configuration in the As Built Format i came across "Microphone Type" under Configuration 7DO-02-01. Changing the Configuration to;
7D0-02-01 -------- [X[b]4XX] [XXXX] [XXXX] and everything worked. this set it to a "VDT" Microphone.
If your having this issue and nothing else is working, check your Mic Type. This explains why the resets, mic changes etc never worked.
Heres a video link i found on it. Hope this helps someone someday.
Old Jan 10, 2022 | 08:26 PM
mrjaw14's Avatar
mrjaw14
I’ve had intermittent issues with sync on my 2011 f250 not “hearing” me. I found the fuse for sync and with key off I pulled the fuse and put it back in a minute or two to restart the sync module. Always works. Fuse is in the passenger kick panel fuse box on mine. Location was listed in the owners manual.
scott9320
2009 - 2014 F150
Feb 10, 2019 10:18 PM
waterdawg
Apr 9, 2008 10:02 AM
ndnejk8r
Modular V10 (6.8l)
Mar 11, 2008 09:11 PM
nate97ranger
1983 - 2012 Ranger & B-Series
16
Dec 19, 2005 08:23 PM
ryankmiller
Nov 30, 2003 05:45 PM
