Diagnosing Valve Train Clatter
Old May 23, 2022 | 03:59 PM
  #91
Byrd.Dog's Avatar
Byrd.Dog
Got all the new valve springs installed on the other head. HUGE PITA with the head still on the motor in the truck. Had to make my own tool to compress them. But got it done & got the motor all put back together. Set the initial timing to 12* BTDC. Engine fired right off & ran very smooth. Only issue is it's bogging right off the line when I hammer the throttle. I'm sure a slight adjustment is required - do I need to add or pull timing to correct this? Rotate distributor clockwise to add more advance, right?
Old May 23, 2022 | 05:36 PM
  #92
Destroked 450's Avatar
Destroked 450
How do you have the vacuum advance hooked up
What carb are you using
Old May 23, 2022 | 08:25 PM
  #93
Byrd.Dog's Avatar
Byrd.Dog
Vacuum advanced is hooked up to port on the carb. It's a 670cfm Holley.
Old May 23, 2022 | 10:17 PM
  #94
Destroked 450
Which one?
The one on the side near the sight glass or the one at the bottom
Should be hooked to the one on the side
Old May 25, 2022 | 07:26 PM
  #95
Byrd.Dog's Avatar
Byrd.Dog
Yep, that's it
Old May 26, 2022 | 05:05 AM
  #96
Crop Duster's Avatar
Crop Duster
670 Holley
Since you have a mild performance cam you should first move the vacuum line to the bottom port and use full manifold vacuum. Hooking the vacuum line to ported vacuum only gets you the 12 degrees initial at idle if you hook it to full vacuum assuming you have a 10 degree can that will get you 32 degrees at idle. That will get you a much more stable idle and higher vacuum. Then readjust the idle mixture. The idle mixture screws shouldn't be less than 3/4 to 1 turn out. This is important If they are in too far you may be to far into the transition slots this will cause all sorts of off idle drivability problems.
If that is a 670 Avenger make sure the accelerator pump is adjusted correctly, ie. the pump arm moves as soon as the linkage moves. You can get bigger squirters and different pump cams to change when and how much pump squirt you get.
Old May 27, 2022 | 12:38 PM
  #97
Byrd.Dog's Avatar
Byrd.Dog
No vacuum can or emissions installed - this engine is in a 60 F250 4x4
Old May 27, 2022 | 01:21 PM
  #98
Crop Duster
I'm talking about the vacuum advance canister on the distributor. Ported vacuum is something that never existed until the Feds got involved with what was coming out the tailpipe.
Old May 27, 2022 | 03:06 PM
  #99
Byrd.Dog's Avatar
Byrd.Dog
Ahh... You have no idea how many threads I've read about ported vs. manifold vacuum - with an equal number of proponents on each side. But I'll try full & see if it runs better. It has always been hooked up to ported, so maybe that was part of my problems all along.
Old May 30, 2022 | 09:16 AM
  #100
Destroked 450
Ported vacuum was used on cars and pickups dating back to the 50's or older, every 60's Ford, GM and Mopar vehicle I owned had the vacuum advance connected to ported vacuum
The first vehicle I remember having manifold vacuum was a late 60's GM with emissions
Old May 30, 2022 | 10:39 AM
  #101
manicmechanic007's Avatar
manicmechanic007
Just drive the vehicle both ways using spark port and manifold and see which way works the best for you
When racing some guys do not want the vacuum advance dropping out as soon as they hit the throttle (manifold) and then having to wait a moment for it to build
Old May 30, 2022 | 10:44 AM
  #102
DaveMcLain's Avatar
DaveMcLain
The real problem with using manifold instead of ported vacuum with an engine that has a cam is that it can be very unstable. Sure it'll sound better because there's more timing but the problem comes when something causes the engine to lose a little vacuum. It get's put in gear, clutch is let out a little bit etc. Manifold vacuum drops a little, timing drops a little, manifold vacuum then drops a little more etc.
built a stock 1963 409 Chevy for a customer to run on the Hot Rod Power Tour one year. In '63 even the dual quad 425 horsepower 409 which this engine was had vacuum advance that was connected to a manifold and not a ported source. This was aggravating and made it difficult to get it to idle just right. What I ended up doing was installing a ported check valve in the line. Advance could go up quickly but went away slowly and this worked pretty well.
Old May 31, 2022 | 10:29 AM
  #103
Crop Duster
Very true.
I've ran into that on these Clevelands. Most of the time since the Ford cans are adjustable you can find an adjustment that keeps it from getting on the rocking chair but still maintains a decent amount of advance at idle even if it stumbles a little. I've had pretty good luck with the V391' 10 degree can in these Durasparks. Since these 351 Clevelands only came with points distributors I ended up with a box full of vacuum canisters before I found the magic one. But that's all part of the fun.
Old Jun 2, 2022 | 08:18 AM
  #104
Byrd.Dog's Avatar
Byrd.Dog
I'm also running the Proform HEI distributor. Anyone happen to know its advance settings vs. stock?
Old Jun 2, 2022 | 08:49 AM
  #105
Crop Duster
Thats a one size fits all distributor. The only way to know the advance curves, mechanical or vacuum is to use a dial back timing light and plot it on your engine or send it to someone with a distributor machine that will check it and recurve it. I use a hand vacuum pump to check and adjust the vacuum advance because an engine that's not under a load doesn't give you a good read on the vacuum advance.
