Yes the springs for the valve rotators are different and have a coil bind height of 1.220 verses the non rotators spring bind at 1.330
So there you go, one can not trust the stock springs unless you physically measure them with a spring tester, something the average shop doesn't do unless requested
The spring you have recommended is similar to the Melling VS280 that's recommended for that cam
As I stated install the recommended springs, or ones from a different maker with similar specs like what you have now recommended
I will add that before using stock springs on cams nearing or exceeding .500 lift have them tested, you won't get spring pressures but one can check lift capabilities and coil bind height with a vice and pair of calibers.
The stock springs that I measured will clear his cam easily. Being .070 away from coil bind is ideal. It would be interesting to test a new set. I also have a stock used set from a 351C without rotators and those won't clear the cam with .508 lift. It is interesting to see how they are different.
My intake & exhaust springs seem Identical, as well as valve stems & retainers.. Going to take my head up to a machine shop to get precise measurements to select the proper springs. I'm way in over my head here trying to pick out anything other than a stock replacement
Exact Melling springs for his cam are the ones I listed # VS280.
Looked them up in my 1991 & earlier Melling parts book I picked up at the PRI trade show in Indianapolis a couple years ago
Why would you run that spring when a stock spring is really a better fit?
Because he doesn't have the stock springs your talking about, he doesn't have the valve rotator or the smaller springs it takes
He probably has the ones like the Cleveland springs you mentioned
And I didn't say to run those springs, I said that's the ones Melling recommended
He can go with the Qualcast 32-909-D springs you recommended for all I care
They can't be identical if you have rotators on the exhaust. Destroked450 is right the Melling VS280 is what is recommended for your cam. That spring is the same spring used on 351C 4bbl engines and 428 FE's.
This is what you have stock: INT. D1AZ-6513-A, closed 80# @ 1.820, open 226 @ 1.39, solid @ 1.33
EXH. D8AZ-6513-A, closed 45# @ 1.8, open 205 @ 1.3, solid @ 1.22
The VS280 is closed 85# @ 1.82, open 270 @ 1.32, solid @ 1.26
Prior to 1978 the 400's used the D1AZ spring on both valves without the rotators on the exh.
Buy yourself a decent set of springs.
And get rid of those rotators. I doubt the things ever worked anyway.
Reason: more words
I think that the rate on the VS280 is too high and that makes the open load too high. 270 open is unrealistic in today's world.
