Sponsored by: Real Truck
6 speed synchros?
Old Dec 31, 2021 | 05:25 PM
jrpitdog's Avatar
jrpitdog
6 speed synchros?
Looking at a 99 with a 6 speed. Owner says 3 and 4th won't engage and 5th pops out. What are the chances this is anything other than the synchros? I don't mind rebuilding the trans if it's just synchros.
Old Dec 31, 2021 | 10:55 PM
Butters123's Avatar
Butters123
Doesn't sound like synchros to me. What do 3rd and 4th do? Synchros would cause the gears to grind on upshift and downshift, but if you double clutch and RPM match you would be able to get it engaged smoothly(ish) depending on your familiarity with the vehicle. 5th sounds like it isn't shimmed correctly, and is not fully engaging so it pops out. I would take it to a transmission shop, and have them drive it. They'll be able to tell you a lot in the first few hundred feet.
thomble17
29
Apr 25, 2020 10:12 PM
F250racer
Ford Truck Parts for Sale
Jan 1, 2014 03:27 PM
DavidE200016936
Sep 27, 2007 10:38 PM
SD250chris
Nov 16, 2005 11:23 AM
