Bad Water pump?
Old Dec 30, 2021 | 03:53 PM
BullnoseLover6.9's Avatar
BullnoseLover6.9
Question Bad Water pump?
Well my truck, 85' 6.9 F350 T19 has a wicked drain and has been eating batteries and regulators but I've got new cables on the way and that ought'ta fix it. However, on those days and nights I'm unlucky enough that my truck cranks out it leaks out a decent amount of coolant. At no other time it does this, only when it slowly cranks over and doesn't start. Anyone else experience this? No clue when the water pump was replaced if ever as I just bought the truck but I plan on going electric when I save up enough. I think I'm going to purchase a spare and keep it on standby.
Old Dec 30, 2021 | 07:27 PM
Robfinger's Avatar
Robfinger
You gonna do an electric water pump??? Why? Just replace the water pump you got now with a like-for-like, electric is asking for trouble assuming you can even find one to begin with.
Old Dec 31, 2021 | 07:35 AM
Prototypemech's Avatar
Prototypemech
New battery cables wont help with your parasitic draw or regulator problem. It may help your cranking issue.
On powerstroke engines, they have a dynamic waterpump seal that weeps a bit if the engine isnt running. Idi's dont have that feature so you probably just have a older waterpump that needs to be replaced. Skip the electric waterpump idea and just buy the most expensive replacement pump you can find, preferably a motorcraft part. The first one has lasted 30 something years, the replacement will probably last just as long.
Old Jan 3, 2022 | 10:25 AM
BullnoseLover6.9
I meant electric fans sorry lol
Old Jan 3, 2022 | 10:37 AM
BullnoseLover6.9
Thumbs up
Ya that's what I figured in regards to water pump. Electric fans I plan on doing and just getting rid of the stock fan, not electric water pump my bad . And in regards to my heavily corroded and rusted cables, on the Bullnose forum on fb they said to start there. Also on a side note how'd you get your truck description in there?
Old Jan 3, 2022 | 12:45 PM
Charmalu's Avatar
Charmalu
Go up to the upper top of the page and click on "USER CP"
then scroll down to edit signature and put in your info.
Charlie
Old Jan 3, 2022 | 01:18 PM
BullnoseLover6.9
Charlie
Thanks, haven't unlocked it yet.
6ohman2004
Dec 26, 2024 12:49 AM
Epd444
Apr 26, 2012 11:18 AM
nat13_3
Feb 6, 2010 07:19 PM
arkredneck
Nov 9, 2007 10:04 AM
just_waitin
Jun 18, 2007 10:39 PM
