94 f150 stinks
Old Dec 26, 2021 | 01:07 PM
Doverfd47's Avatar
Doverfd47
94 f150 stinks
Hello everyone. Nice looking forum you have. I found it while searching for a problem. I just wanted a truck to haul occasional items and I wanted the old body style. Found a 94 xlt 2 wheel drive with 90000 miles and pretty decent for age and price. Fixed a few items already but kind of stumped on one problem. It stinks somewhere between hot garbage and port o potty stink. Got worse when running hvac. I should’ve known when I saw bunch of air fresheners lol. I can make it go away briefly by spraying some air freshener in intake outside below windshield. It’s been hard to search solutions. Has anyone run into this?
Old Dec 26, 2021 | 01:34 PM
jas88's Avatar
jas88
You may have a dead mouse in your fresh air plumbing. If so, it will eventually go away, but it takes a while.
Old Dec 26, 2021 | 02:37 PM
Prototypemech's Avatar
Prototypemech
The hvac system gets fresh air from the grill area in front of the windshield (aka, cowl). Its open to anything that wants to make a home in it like insects. Also, pine needles and other vegetation often falls in there and gets stuck. Im guessing you have a science project growing underneith your cowl. You can take off a few screws from inside the engine comparment and take off your wipers to clean out the cowl. If you dont find a bunch of slime in there, than it the smell is probably in your hvac system, which is alittle harder to clean out.
Old Dec 26, 2021 | 02:38 PM
yardbird's Avatar
yardbird
But the pee smell remains a loooong time. Had that happen in a 2 ton IH truck we used in the winter. Smell would almost run you out of the cab.
Old Dec 26, 2021 | 03:03 PM
Robfinger's Avatar
Robfinger
When rebuilding my brick years ago I swapped in a dash that was in better condition. Was gonna keep it intact with the air ducting and all, till I smelled mouse pee in the upper vents. Donor truck hadn't been used in a long while, and there were no traces of mice actually living up there, still all the ducting got tossed away and the one from my old dash moved over to the new one. And while the fenders were off, a sheet of razor-sharp expanded steel mesh was installed in the fresh air intake to hopefully stop the little effers from ever getting in there again.
Old Dec 26, 2021 | 04:16 PM
AuroraGirl's Avatar
AuroraGirl
Use a ozone generator its not very difficult
got carpet? Is your truck leaking at the center of the windshield at the top? Mine was, vinyl floor but it made it humid and it made the seat eventually soak it up and be damp. I ran a heater in there and used ozone generator. Sprayed seat with a water shed thing and sealed the windshield, back window leaks. nice and good now.
Old Dec 26, 2021 | 04:17 PM
AuroraGirl's Avatar
AuroraGirl
My gmc has this problem right now. Ickkk.
rmalottwtes30
Mar 10, 2009 06:40 PM
JCooke
Jun 11, 2005 06:21 PM
Tex67
Jun 10, 2002 12:08 PM
