Wiring help needed
Old Jan 3, 2022 | 09:34 PM
  #31
Dpa2222's Avatar
Dpa2222
This is the wire that F150LEDS said that it look correct. I ran out of daylight Sunday and it’s been raining and snowing here today. I will let you know. I say hold off until I can verify that is the correct wire
Old Jan 6, 2022 | 03:07 PM
  #32
Dpa2222's Avatar
Dpa2222
Correct wire
I found that color of violet/gray to not be correct. I’m not sure which wire it is at this time
Old Jan 6, 2022 | 03:41 PM
  #33
mewaschuk's Avatar
mewaschuk
Question
i believe there are 3 wires of the same color that do not all have the same function. check/try again???
Old Jan 7, 2022 | 11:43 AM
  #34
jrx13's Avatar
jrx13
I'll take a pic of my truck and where I tapped when I get back to my truck next next weekend. I switched to driving car to save on fuel haha.
Old Jan 7, 2022 | 12:43 PM
  #35
Dpa2222's Avatar
Dpa2222
Wiring help
I do appreciate that. It will be interesting to see what you were able to use
Old Jan 14, 2022 | 07:47 AM
  #36
Dpa2222's Avatar
Dpa2222
Wiring help needed.
Did you get chance to look about the wire color you used for power?
Old Jan 15, 2022 | 01:20 PM
  #37
Rick_from_Mass's Avatar
Rick_from_Mass
Same here, curious to know
Old Jan 15, 2022 | 01:48 PM
  #38
jrx13's Avatar
jrx13
OK just got back to my truck this weekend. Again 2021 XLT, passenger side panel . Dome light wire that I tapped into.
Old Jan 15, 2022 | 03:25 PM
  #39
Rick_from_Mass
Where did you run your wire thur for the lights
Old Jan 15, 2022 | 05:23 PM
  #40
Dpa2222's Avatar
Dpa2222
Wiring help
Thanks for the pic. Much appreciated. What is the wire tap that you used?
Old Jan 18, 2022 | 08:10 AM
  #41
Rick_from_Mass
keep us updated how you made out with your lights install
Old Jan 24, 2022 | 06:05 PM
  #42
Rick_from_Mass
Dpa2222 we’re you able to finish your wiring?
Old Jan 24, 2022 | 06:15 PM
  #43
Dpa2222's Avatar
Dpa2222
Wiring help needed
No I have not. My wire that is gray/ violet is not the correct color wire to use. I’m not sure at this time what I going to do
TimothyBarron
Nov 30, 2023 07:40 AM
gadawg31
May 4, 2018 01:35 PM
sidwaz
Jan 20, 2009 11:23 AM
sk83r005
Nov 21, 2005 09:57 AM
1988-Ranger-FL
Electrical Systems/Wiring
Jul 25, 2003 03:28 PM
