Is there anywhere other than the dealer that I can get these keys duplicated?
I was under the impression this key is not a smart key and I just need the physical part to run the truck. True? (no remote start, very basic Lariat) Maybe if I use the physical key and enter the door code?
I wonder if you can buy a flip key and get it cut somewhere and then program it yourself? I know that I did that once in a 2016. Procedure was in the manual I believe to code extra keys.
I believe....if you have 2 fobs you can add a 3rd yourself after buying one on ebay etc. and getting it cut, there's a procedure. I ran one of mine over with my lawn mower and called a mobile locksmith. He came to me, cut and programmed the new fob in about 10 minutes. Charged $230 cash. He does all the keys for lots of dealers in the area. Sourcing, getting one cut and then programming would be cheaper but not something I wanted to research.
