I have a 1992 ford van e 150 5 liter AOD transmission . It want go out of second gear and sometimes it roars when starting from a stop. So I'm pretty sure it shot, wondering if you can replace it with a C6 transmission or do I have to go back with the AOD ? I don't think its worth paying to have it rebuild 2 to $5000.00 dollars, so should I try and find one at a savage yard for 200.00 dollars. Also, I've never pulled a automatic trans, I've pulled a few manuals, so how messy or hard is it to pull one ? Thanks f1butcher
Are you sure it has an AOD? What is the trans code on the drivers door pillar? T is for an AOD but W would be the 4R70w computer controlled version and both of these were used in '92.
Thanks, I saw a 1993 van at salvage yard a couple of weeks ago, but it had a outer blue casing , wondering if it was like a different company trans. and not made by Ford. I need to go back and see if it is an AOD or not by the letter T. It looked like an AOD.
I guy I ran into has a 351 engine and a C4 trans hooked to it for sale. Said the C4 would hook up to my 92 van ok, but I think the C4 would be a little weak for a E150 van ?
Also went to a salvage yard last week they had several ford vans and saw the trans code U and some where E . I don t know what these trans are, I need a code chart of the ford trans for vans and trucks, so if anybody can tell me where to look let me know. Thanks
Wondering if the 4R70W or the E4OD trans will fit my 92 ford van that has the AOD in it ? I guess it would have to match the bolt pattern and length , plus the cable linkage.
