Gasket sweating.
Old Dec 18, 2021 | 05:36 PM
alliz1986's Avatar
alliz1986
Gasket sweating.
Hi everyone! - I was under my truck today for an oil change… and noticed this. I’ll take it in and have it looked at but would appreciate any feed back or questions for the service guys.
thanks everyone!
I’m no mechanic but I believe it’s the tranny. Oil level is good I checked it right away.
Old Dec 18, 2021 | 05:43 PM
FishOnOne's Avatar
FishOnOne
Yes that's the transmission oil pan. Very rare that these leak so you may want to simply snug the bolts up a bit to see if they're loose.
Old Dec 18, 2021 | 05:57 PM
alliz1986's Avatar
alliz1986
thanks! - I’ll track down the torque specs and do it tonight 👌🏽
Old Dec 18, 2021 | 06:34 PM
05F250DSL's Avatar
05F250DSL
I’m not sure how many miles you have on the truck but it might be a good time to do a trans service, filter change and install a new gasket. I second I would first check the tightness of the bolts.
Old Dec 18, 2021 | 06:49 PM
alliz1986's Avatar
alliz1986
65,000 kms (40,000miles)
And thanks! I was thinking the gasket will probably need to be done but didn’t even know there was a filter for the transmission.
Old Dec 18, 2021 | 06:56 PM
mattymax's Avatar
mattymax
Gasket will be reusable. I think the torque spec is about 10-12ft lbs. I’ve done many services on my 08 and 12 lbs is really not a lot.
Look really well and make sure the leaks not coming from above somewhere
Old Dec 18, 2021 | 07:48 PM
Joe T's Avatar
Joe T
Its under warranty.
I would hope they put new fluid back in.
Old Dec 18, 2021 | 07:57 PM
alliz1986's Avatar
alliz1986
Originally Posted by Joe T
Its under warranty.
i deleted the truck… so I’m guessing they’ll come up with something about it having more power or something and not cover it.
we’ll see next week I guess.
Old Dec 18, 2021 | 08:02 PM
Joe T's Avatar
Joe T
Doubt it would affect a gasket.
Old Dec 18, 2021 | 10:12 PM
HRTKD's Avatar
HRTKD
Transmission pan bolts on the 6r140 are 80 lb in according to the service manual for my 2017. Do not over torque these bolts. That's only 6.6 lb ft. Most torque wrenches cannot go that low reliably. Find someone with a 1/4" digital torque wrench if you can.
Old Dec 18, 2021 | 11:49 PM
willynilly's Avatar
willynilly
if it were mine i would drop the pan , change any filters while i was there and use new gasket since you dont know if the old gasket is compromised and perhaps thats why its leaking in the first place.
the book may have a specific crisscross tightening pattern. if not then just do a even crisscross like lugnuts. any half decent inlb wrench that starts off around 25 should be fine.i see no reason it has to be digital.
Old Dec 19, 2021 | 04:55 AM
M1A4ME's Avatar
M1A4ME
Used to be transmission filter kits came with a new gasket.
Be sure to get the right transmision fluid. Ford has changed some over the years and it's different stuff, or some transmission use different fluids.
The advice about the 1/4" torque wrench that can be set in inch pounds is good advice. It's really easy to strip the threads out, break a bolt, or damage a gasket if you overtighten.
Not a bad idea to change that transmission fluid/filter every 40,000 miles either. A few quarts of fluid, a filter kit and an hour of time every few years beats the cost of replacing the transmission one of these days.
Old Dec 19, 2021 | 05:16 AM
manicmechanic007's Avatar
manicmechanic007
That sweating gasket will develop into a dripping leak soon
I agree it is rare to have a trans pan gaskets leak now days with the reusable gaskets
Someone may have serviced it and replaced the gasket with cork or rubber?
Buy a new pan for it with a drain plug if you can afford one (or weld a drain plug in your pan)
Yes invest in a 1/4 inch torque wrench
If the gasket has been replaced go get another new expensive one from Ford
That combined with your new drain plug will make your truck much nicer to service
Old Dec 19, 2021 | 08:17 AM
FormerChev's Avatar
FormerChev
Not to hijack, but if I’m reading correctly, the pan will have a reusable (rubber) gasket with no sealer/rtv?
and the filter is just pressure fit?
thanks in advance.
and to stay on topic, if the gasket is reusable with no sealer, I would expect OPs just needs a tightening.
Old Dec 19, 2021 | 08:56 AM
HRTKD's Avatar
HRTKD
I wasn't looking specifically for the filter torque, but I do recall seeing it. So there is a bolt on the filter.
