Is this beyond saving?
Old Dec 12, 2021 | 11:13 AM
BradGilyard's Avatar
BradGilyard
1961 F100. I ordered new cab mounts and pans, but not sure where to begin.I don't see anywhere to weld the new mount onto. Is this beyond saving? Or I can just drive it as is.
Old Dec 12, 2021 | 12:54 PM
Christmas's Avatar
Christmas
I wouldn't touch it with a 10' pole. Plenty of good trucks out there to be had that won't test your patience.
Old Dec 12, 2021 | 01:02 PM
BradGilyard
Too late lol already in the garage
Old Dec 12, 2021 | 01:11 PM
KO1960's Avatar
KO1960
I would determine what is salvageable, then find yourself another truck. As Christmas said, there are alot of trucks out there with a better starting point.
Old Dec 12, 2021 | 01:22 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
You can get a pretty decent-condition, relatively rust-free, running truck in the western states, for around 5-7K, way less than what you’d ever spend getting one into decent shape. Fly-n-drive, in four or five days you’re back home, saving money, months or years of headaches, and you’ll get to see some of the country, to boot.
Old Dec 12, 2021 | 01:24 PM
KO1960's Avatar
KO1960
That's a good plan.
Old Dec 12, 2021 | 01:28 PM
Crop Duster's Avatar
Crop Duster
Well drag it back out. Unless there is sentimental value. Seriously, what I'm seeing there will take a frame off and months to repair. A lot of that rusty stuff is reproduced but some of it isn't and will require a donor truck or the skill to make it yourself. I would bet the rear stiffeners on the front fenders are gone also. Good Luck.
Old Dec 12, 2021 | 01:31 PM
BradGilyard
This is not a restoration. Just a weekend driver.
Old Dec 12, 2021 | 01:33 PM
Crop Duster
In that case leave it alone and drive it. Until you run across one thats worth fixing.
Old Dec 12, 2021 | 01:43 PM
ibuzzard's Avatar
ibuzzard
Drop back fifteen yards and punt!
Old Dec 12, 2021 | 01:56 PM
yardbird's Avatar
yardbird
Is this a unibody truck or a regular cab and bed? If not a unibody, I would look for another cab.
Get under the truck with heavy sheet metal/steel, jack up the cab, and slide the metal where you can and bolt/rivet it from above to what metal you have. This is only for support to keep the cab from collapsing around the mounts. It's already started collapsing under the clutch pedal.
Drive it and keep looking for a cab. I would put as little as possible into this cab to keep it going. Hammer and rivet metal where you can to cover the holes to the outside.
Old Dec 12, 2021 | 06:49 PM
DrCharles's Avatar
DrCharles
Anything's fixable with enough patch panels and MIG welding wire...
But I do agree, at some point getting another cab would be better.
(Don't forget, rust is always worse than it first appears!)
My '65 F-350 had significant floor and A-pillar rust, although not as bad as yours. It took me two months and about $700 worth of panels from Carolina Classics. The thread is on this forum:
https://www.ford-trucks.com/forums/1...body-work.html
Good luck, whatever you decide to do!
Old Dec 13, 2021 | 01:16 AM
7BercMerc's Avatar
7BercMerc
The complete floor pan is reproduced, steps and all. I would look to that route if you cannot find a donor cab. Don't try and get all the other pieces individually. Even though they are available, welding them together would be a nightmare. Replace thewhole floor as one.
Old Dec 13, 2021 | 06:03 PM
53deere's Avatar
53deere
I'll second this. If you have more time than anything else you can fix anything, and if you don't need it to look original it's even easier. You could even weld in some heavier gauge diamond plate for the floor or any other heavy gauge sheet metal you can source for cheap.
Old Dec 14, 2021 | 10:11 AM
sgettin's Avatar
sgettin
Depends on what you like to do. Your truck is similar & maybe not quite as bad as mine (mine was sunk onto the frame, rust up the firewall from mud splatter, doors sprung, bottom half of the A and B pillars gone etc.). Anyway I like welding in panels I can buy & making a few I can't so that's what I did. I also don't like driving six states west to get a new cab so screw it I fixed what I got & it turned out pretty good. There's a short thread I put up on my rebuild a few years ago in the archives somewhere if you want to check it out.
If you want to try it go ahead it's a ****** ton of work and time though (gets to be a bit of a rabbit hole) & won't look as nice as if you buy a good replacement cab etc. As far as price goes it may be a bit of a wash if you get a fare priced cab since replacement panels cost some $$. Doing it myself was probably cheaper for me than hunting up a new cab but not by much especially if you consider my time but like I say I enjoyed it so...
Good luck.
