The scanner is a snap on ethos. The check engine light was on that is why I scanned it
Does that scanner automatically detect which vehicle its scanning? My modest Actron scanner requires me to enter the vehicle pertinent information; manufacturer, year, fuel, model, engine CID and trim level.
It looks like it could be bad connection on the MAF Sensor, or the Pressure sensor on the fuel rail or both.
The Fuel Rail Pressure Sensor doubles as manifold absolute pressure sensor, that's why it has a vacuum line on it.
Check the electrical connections on those two sensors, and the condition of those sensors. You can get the Rail sensor for like 30 bucks on amazon, just look for the bosch one, the MAF might be a bit more expensive.
