Modular V10 (6.8l)
MAP SENSOR
Old Dec 11, 2021 | 08:26 PM
J3ROMEB10's Avatar
J3ROMEB10
MAP SENSOR
I am trying to locate the MAP (manifold absolute pressure) sensor on my 2001 ford f250 v10. I am getting various codes. One of them is p0108
Old Dec 13, 2021 | 03:28 PM
projectSHO89's Avatar
projectSHO89
You can stop looking, it doesn't have one of those.
Post ALL of the codes, in the order that they are displayed by the scan tool.
Old Dec 13, 2021 | 07:59 PM
J3ROMEB10's Avatar
J3ROMEB10
Here are the codes:
P0108
P0104
P0102
P0101
P0110
Old Dec 13, 2021 | 08:00 PM
J3ROMEB10's Avatar
J3ROMEB10
Here are the codes
P0108
P0104
P0102
P0101
P0110
Old Dec 13, 2021 | 08:33 PM
projectSHO89
What did you read those codes with? The majority of them should not exist on the vehicle you identified.
What symptom or issue got you started on this show?
Old Dec 13, 2021 | 08:40 PM
J3ROMEB10's Avatar
J3ROMEB10
The scanner is a snap on ethos. The check engine light was on that is why I scanned it
Old Dec 14, 2021 | 05:36 AM
JWA's Avatar
JWA
Does that scanner automatically detect which vehicle its scanning? My modest Actron scanner requires me to enter the vehicle pertinent information; manufacturer, year, fuel, model, engine CID and trim level.
Old Dec 23, 2021 | 07:59 PM
hav24wheel's Avatar
hav24wheel
Is yours a EGR motor? Ford put the MAP in the EGR comments on some vehicles.
Old Dec 27, 2021 | 12:08 AM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
It looks like it could be bad connection on the MAF Sensor, or the Pressure sensor on the fuel rail or both.
The Fuel Rail Pressure Sensor doubles as manifold absolute pressure sensor, that's why it has a vacuum line on it.
Check the electrical connections on those two sensors, and the condition of those sensors. You can get the Rail sensor for like 30 bucks on amazon, just look for the bosch one, the MAF might be a bit more expensive.
jmo1112
Nov 2, 2017 02:14 PM
VCB
Modular V8 (4.6L, 5.4L)
Mar 29, 2014 07:34 PM
MONAVIERONJON
Jun 17, 2013 08:06 PM
Talyn
17
Jun 19, 2011 02:06 PM
