Lost trailer brakes today on my 2022, not trailers fault.
The following users liked this post:
Unfortunately, as it often is in the airline and automotive industry, nobody gets around to doing something about such a problem until somebody dies.
How much weight can superduties safely stop if trailer brakes go out without risking an accident? This is a huge fear for me since almost losing a load I was driving home from Alaska to Oregon with an F150 a decade ago. One spot on the ALCAN Canada doesn't advertise the 12% grade with a lefthand turn in the middle until you are already deep into it.
Anyone else think the factory plug feels cheap? I noticed this the first time I towed with my '22. Had Toyotas prior and plugging in to those was much more positive and secure feeling. The fellow above who mentioned replacing the factory plug might have the solution. In fact when I saw that post i thought 'aha, i was right!'
Find the CEO email posted to be questionable given the grammar error.
The following 2 users liked this post by stryder:
#29
I was thinking back when I first hooked up Forscan to the truck to download all of the module information. One thing I noticed is that I had some DTC's on my brand new truck that I had to check out. Now none of them looked all that serious and I wasn't too concerned because none of them were tripping a Check Engine light, but there were a couple that read something like "Loss of Communications with Trailer Control Module". It may not be the exact wording, but close. Keep in mind I haven't pulled a trailer with this truck yet. I wonder if this is what's causing the loss of brakes and the software fix that Jim Farley was referring to?
#30
i chased trailer brake problems for a week and even rewired plus new lights still it would drop the trailer, only to see it again, then loose it
after much brain hurt. i plugged in forscan and it led me right to the problem, after i troubleshooted by only plugging in the 4 wire connection to two vehicles. then i knew it was specific to the 7 way plug. the brake module did set a dtc and it was about trailer break away battery being out of spec or dead IIRC.. you would think the trailer screen would show you the faults, instead of the generic unconnected message
i checked the breakaway battery and found it was dead dead dead. put in a new one and BING truck saw trailer and no more issues
battery was set to grab a charge when plugged in, but the battery had failed inside, most likely from being at zero for .....i have no idea when it was charged last.
https://www.ford-trucks.com/forums/1...ht-issues.html
post 13 has more detail
