NEED SOME HELP
Old Dec 8, 2021 | 01:37 PM
Millertime89's Avatar
Millertime89
Trailering
NEED SOME HELP
kinda new to the forum but have learned lot from you guys reading through them over the years so thought i try and post my problem. Ok, guys need some help here, i have a 97 f350 7.3 pretty close to stock it has a 6in lift with 37s. a electronic fuel system, and a 4 in straight from the downpipe back. it has a newer cps, icp and ipr all from ford. the uvch for both sides are new. the injectors are the original set with 325k ik its on my list. Ran pretty smooth. ok now to the problem, i drove it to a gas station about a mile from my house went in, and left it running to warm it up, when i came back out it had died. very odd( thinking back it had done this maybe 2 or 3 times before but always started right back up) got in and it started but sounded very rough, put it in drive and rolled forward and it died, tried to start it again and wouldn't start without pumping the accelerator and even then, same thing ran incredibly rough and die, after two or three times of doing this it failed to even start with pressing the accelerator. just turns over. had it towed back. this happened about 3 weeks ago had to leave town for a bit, so trying to tackle it now. I'm leaning to the idm but only because yrs ago it died and died something similar, but i have no solid info to point me to that. would appreciate any thoughts you guys have on the problem.
Old Dec 8, 2021 | 04:52 PM
farmert's Avatar
farmert
My first thought is the lift pump in the valley died. Have you tried getting a fuel pressure reading? You should see at least 20lbs. while cranking.
Old Dec 8, 2021 | 07:35 PM
96 OBS's Avatar
96 OBS
He said it’s efuel converted. Do you have fuel pressure gauge? Hear the pump? Do you have a way to check codes?
Old Dec 8, 2021 | 10:43 PM
farmert's Avatar
farmert
Whoops missed that. The pump in the valley couldn't have died then. LOL The Epump could have though.
Old Dec 8, 2021 | 10:49 PM
96 OBS's Avatar
96 OBS
Definitely lol agree with @farmert tho sounds like it’s struggling for fuel by your description
Old Dec 9, 2021 | 08:50 AM
Millertime89
Trailering
so the electronic fuel system i installed on it, cut out all of the stock mechanical fuel parts, fuel bowl, fuel pump ,etc and was mounted on the rear frame much like a aftermarket lift pump the pump is working and the guage on the front by the regulator says it has 65 psi. i will see if that moves when i crank it. would bad fuel cause it to just cut out and not start?
Old Dec 9, 2021 | 08:53 AM
96 OBS's Avatar
96 OBS
It would have to be really bad fuel. When it cranks without start, does it smoke out the tailpipe? Maybe try unplugging the ICP when it doesn’t start and try again
Old Dec 9, 2021 | 08:59 AM
Millertime89
Trailering
unplugging the icp was one of my first thoughts no change i also changed out the cps sensor just for ****s and giggles, from my mirror it looks like alittle white smoke but its pretty cold too
Old Dec 9, 2021 | 09:02 AM
Millertime89
Trailering
maybe I'm just missing something small what would you guys recommend as kind of a no start check list of types
Old Dec 9, 2021 | 09:08 AM
96 OBS's Avatar
96 OBS
https://drive.google.com/file/d/0Byb...1qRU1VVGc/view
got you fella
Old Dec 9, 2021 | 09:13 AM
farmert's Avatar
farmert
Do you know anyone who has an OBS with a 7.3? You could take your IDM off your truck and plug it in theirs. No need to bolt it to the fender, just attach the wiring harness. If the problem follows the IDM to the other truck, you have found your problem. Your IDM will fit a NBS truck but it taakes a lot mor to install it in the NBS as the drivers side inner fender has to be removed to access it.
Old Dec 9, 2021 | 09:15 AM
Millertime89
Trailering
wow lol thanks thats perfect
Old Dec 9, 2021 | 09:18 AM
Millertime89
Trailering
i don't i wish i did. so the wait to start like kinda flickers when i turn on the key not sure if thats anything? i will try and run though some of whats on that list and give un update
Old Dec 9, 2021 | 09:59 AM
Millertime89
Trailering
ok so i got my hands on a code reader from a buddy just a simple one nothing fancy but it had three codes p0475, p01711, p1298 the first two are pretty generic the last on is idm failure. ik pretty self explanatory and this is probably a stupid question but is there any other reason you guys can think for it to throw that
Old Dec 9, 2021 | 10:10 AM
farmert's Avatar
farmert
Kind of sounds as if you have found your problem. Maybe bad wiring to the IDM can cause the p1298 code, but am not sure.
Jesse Hales
19
May 2, 2020 09:37 AM
bubba_3711
Oct 31, 2012 07:11 PM
Sean Estes
34
Aug 8, 2012 10:02 AM
BIG B SMITH
Feb 4, 2005 10:25 PM
