New Pics!
Old Nov 10, 2003 | 05:03 PM
  #61
true4.2's Avatar
true4.2
miss post
Old Nov 10, 2003 | 05:07 PM
  #62
strick88's Avatar
strick88
well, im getting pretty close to having the money so im trying to figure out a few things.............mainly I want to know if i should put my trigger on the accelerator or if bc I have a standard and dont want to blow my motor with a missed shift.........maybe a button somewhere would be better.
Old Nov 10, 2003 | 05:30 PM
  #63
true4.2's Avatar
true4.2
Personal opinion would be my guess. I'd have a button to push for easier access. Also, you could get more precise shots in with the 'touch of a button' IMO. Ever seen ~Gone In 60 Seconds~? When he pushes the 'go baby go' button? Also, in (and I hate this movie) 'Fast and the Furious' where they all hit buttons to boost out. That would seem to me the better way to go, but I've never had NOS.
Old Nov 10, 2003 | 05:34 PM
  #64
strick88's Avatar
strick88
button it is , thanks
Old Nov 10, 2003 | 05:48 PM
  #65
true4.2's Avatar
true4.2
No problem...that's just my opinion on NOS accessibility I guess.
Tom?
Old Nov 10, 2003 | 07:12 PM
  #66
Busa01's Avatar
Busa01
Hey man! I talk to you about nos all the time. Even told you I would take pictures of EVERYTHING for you and email them to you personally.....
Your kit comes with 2 safety switches. One switch you mount on your dash and the second HAS to be mounted on the throttle. I'll take up close photo's to show you exactly where.
The importance of the throttle switch is that you DON'T want to engage the nitrous unless your foot is to the floor, full throttle.
The other switch is connected to the throttle switch. They both need to be engaged for the nitrous to work. These are for safety reasons.
You can operate the nitrous in 2 different ways.
1. You can full throttle your truck and wait until you hit 2000+ rpm, then throw the dash switch.
2. You can throw the dash switch and 3/4 throttle until you hit 2000+ then punch it.
Either way works, you'll just have to practice to see which one you like best.
I prefer to full throttle it first (so my 60 foot times are the best they can be) then flip the dash switch when I hit 2000, which only takes a split second really.
When your shifting, you will be taking you foot OFF the gas to disengage the clutch. When you do this, the nitrous system will shut of because you foot is off the gas. If you try shifting super fast like superman and you miss shift, then apply your foot full throttle again and hit the rev limiter, your in trouble.
Also, If you mean to shift it into 2nd, but you miss and drop it in 4th and full throttle, your in trouble.
Take your time in the beginning. It's ok if you miss shift, just DON'T FULL THROTTLE. 3/4 throttle in the beginning until you know what gear your in, if any at all.
You don't have to speed bang it with the gears, because when that foot hits the floor and the nitrous engages it's going to suck you back into your seat like your launching a space craft.
So take it slow. It's a very fun learning process.
Don't try to learn everything in 1 week. It's impossible. Take you time and have fun.
Start with the little 35 shot. If you screw up with the 35 shot (misshift or something) your not really going to hurt anything because it's not that strong of a boost.
But the 35 shot is where your going to learn everything about nitrous BEFORE you move up to a 50 or 75.
Capice???
Oh, and by the way.
I Just got done doing the high speed trial run. Mind you it's raining out and very very windy so I could only get high speed in spurts, but I was able to reach (with traffic) just under 100mph smooth as a babies buttocks!!! smoooooooth.
wow, worth every penny. I'm glad it worked out. I was worried.
But it's awsome...so, problem fixed...(finally)
Tom
Old Nov 10, 2003 | 09:52 PM
  #67
strick88's Avatar
strick88
thanks, Im counting on those pictures............I just hope i can install it on my on.............I think with ur pics and just taking my time, I will be fine....................do u have a purge vavle those are so kewl..............
Old Nov 11, 2003 | 10:11 AM
  #68
Busa01's Avatar
Busa01
No I don't have one yet.
If you wait until your ready to run before you turn your bottle on, you really don't need one.
Purge valves are good for those who may leave their bottles on in between races, perhaps because they are not as easy to access as mine.
When I turn my bottle on, it shoots liquid nitrous into my lines. So i'm good to go.
The purge valve is there for when you leave the bottle on and the liquid nitrous, from being in the lines for a bit with the engine hot, begins to evaporate. Well, you get your best spray if your first spray is all liquid.
However, I still plan on getting one once i get bored of my current set up.
This is what is so fun about nitrous. There are so many "Add-ons" you can get, that the fun never stops baby!!!
I was thinking about a problem you might have.
If you view my gallery, you will see how I have my bottle mounted behind my seat in the supercab section. This is great for security purposes as well as convenience in opening and shutting the bottle.
if you have a single cab, you may have to mount you bottle in the bed of your truck.
if that's the case, your going to need an automatic bottle opener.
This automatic bottle opener comes with a kit that also include the blow down valve, bottle heater, and purge valve. I think the kit is 350.00. You may need that.
Also, if your mounting the bottle in the bed of your truck, your going to have to get a tonno cover, you can leave all that stuff out in the rain dude.
so this may be an extra expense for you.
My Extang cover was only 189.00. You may need one.
OOOORRRRR, you can mount your bottle on the passenger floor of your truck. This may be a small inconvenience to passengers but is ok.
Wherever we install it. The bottle MUST be facing forward with the nozzle pointed at the floor. You can't mount your bottle sideways behind the seat.
Tell me what you think about bottle location.
I think the passenger side is the best location. It will save you from having to get the automatic bottle opener and bottle heater.
Tom
Old Nov 11, 2003 | 09:19 PM
  #69
horizonhuskies's Avatar
horizonhuskies
I dunno about your lay out strick, but under my pasenger seat is where my jack and mounting hardware is for that, be prepared to remove your bench or pass. seat in order to install and mount.
Garrett
Old Nov 11, 2003 | 09:42 PM
  #70
strick88's Avatar
strick88
passenger floor it is, thats where i want it..............my girlfriend can ride in the back............
Old Nov 12, 2003 | 07:23 AM
  #71
Busa01's Avatar
Busa01
The bottle sits at about a 35 degree angle. The rear of the bottle is pretty close to the floor and I think will even fit under your seat some. This will allow you room to access the hoses and pressure gauge. Just make sure nobody jams your seat forward without you there. I have people do that all the time with me. If I take my car to get cleaned or something, the guy always jams my seat all the way back and smashes the seat into the bottle nozzle. This always makes me mad because it's so stupid that they don't look before they do things, even though I tell them to be carefull of the bottle.
Strick,
Just remembered, the stock kit does NOT come with a pressure guage. This is stupid, because it's absolutely necessary to have one. You'll have to purchase this seperately, either from Jegs (if they have one in stock) or from NX. NX charges alot more for their parts than Jegs does. I think it's like 40 bucks or something. You have to have the pressure guage because you want to keep your bottle pressure in the green.
Even after a full bottle, if it's cold, will not register in the green. especially in the cold months. I didn't buy a bottle heater because they are 300.00.
Instead, I sealed off all my floorboard heating ducts except for 1. Then I ran a 2 inch tube from the last duct to under my bottle. I wrapped my bottle with a towel to keep the heat in. If I know I'll be boosting during that ride, I'll crank the floor heat on. This will blow the hot air under the bottle and heat it up into the green, and even a little into the red, in just a few minutes.
This is MY idea and I'm going to have it pattented. I bet no body else ever thought of this.
I have pictures of this on my second page of the picture gallery.
......mmmm...i'm so smart.....
Tom
Old Nov 13, 2003 | 06:10 PM
  #72
true4.2's Avatar
true4.2
Yes Tom, you are smart...I guess. HEY! You knew about the whole picture/CD thing! You gotta be smart to know that!
Old Nov 13, 2003 | 08:17 PM
  #73
strick88's Avatar
strick88
since mine will be right there on the pass. floorboard the floor heater will blow right on it. do u think that will heat it enough.
Old Nov 14, 2003 | 08:40 AM
  #74
Busa01's Avatar
Busa01
It's all trial and error. That heater gets pretty darn hot. almost enough to burn your hand if you put it up against the bottom vent.
just stuff some rags in the drivers side so it all blows out the passenger side. You may want to run a small tube from the vent to under your bottle, then cover your bottle with a towel to keep the heat in.
In the colder months i'm going to try this.
Since I already have a blanket on my bottle, i'm going to buy a therapudic heating blanket 2' X 2' and wrap my bottle with that and plug it into my inverter. Those blankets get 188 degrees and are only 29 bucks. That should really heat things up in the winter months.
Justin73supercamper
May 31, 2016 03:46 PM
anexforsix
Nov 24, 2015 02:09 PM
rtcalabrojr
28
Sep 11, 2009 09:54 PM
aldrichg9
User Gallery & Picture Display
Mar 3, 2009 03:29 PM
greenhornet
New Member Introductions
Nov 4, 2002 10:16 AM
