97/98 transfer case
Old Dec 2, 2021 | 12:44 PM
RacerJames's Avatar
RacerJames
97/98 transfer case
So I bought and installed a '98 transfer case in my '97 Explorer. The '98 has no provision for the '97 speed sensor.
Oops.
After a lot of searching, I know the following:
'98 Explorers use the rear ABS sensor at the axle for speedometer, Speed Control Servo, radio volume, GEM, etc.
'97 Explorer The VSS has 2 wires coming from it, one is grounded in the PCM. The other goes to the GEM, as well as the speed control servo, and also to Pin 33 of the PCM.
Does the VSS in the '97 transfer case send the same square wave as the ABS sensor in the axle?
Could I splice the VSS sensor wiring into the rear ABS sensor on my '97 in order to make the speedo and cruise work?
Old Jan 5, 2022 | 04:22 PM
RacerJames's Avatar
RacerJames
It appears that either nobody's looking at this website, or nobody has an answer to this rather technical question.
Old Jan 5, 2022 | 04:27 PM
85e150's Avatar
85e150
Shows 85 views, not bad compared to other threads started at the same time. I think it's a matter of "no one knows".
Do you have a way to measure the output, to see the "square wave"?
I suppose if you hooked it up as you suggest you might risk damaging other components.
Old Jan 5, 2022 | 04:33 PM
RacerJames's Avatar
RacerJames
Unfortunately I don't have a graphing DVOM like the Fluke unit the shop I once worked at had, so, I'm hoping someone here has had experience with both sensors.
Old Jan 18, 2022 | 11:36 PM
RacerJames's Avatar
RacerJames
Originally Posted by RacerJames
It appears that nobody has an answer to this rather technical question.
I remembered receiving training on ABS back in the mid '90s and dug out the books I had saved from it. The pictures are from the '95 Explorer TEBS diagnostics pages. Apparently, the sensor in the rear axle should produce 6 mv/hz or more.
I'm wondering if anyone has the equivalent diag procedure for the speedometer speed sensor? Is it's output the same?
Turmand
1983 - 2012 Ranger & B-Series
Mar 15, 2015 10:54 AM
77mud
1997 - 2003 F150
Nov 23, 2011 08:59 AM
jaystersj
Apr 11, 2007 01:15 AM
kevinupchurch
Offroad & 4x4
17
Mar 12, 2006 10:59 PM
bmoga
Oct 18, 2004 02:42 PM
