Older OEM Wheel Compatibility
Old Dec 2, 2021 | 09:09 AM
aagiv's Avatar
aagiv
Can someone tell me what year range these Ford wheels are from and if they would clear the calipers on a 2021 F250? Pretty sure I’ve seen folks say that only steel 17” fits on 2017+ (OEM, not aftermarket), but want to reconfirm. These are listed for sale locally and they look sharp. Also, does anyone know if they’re 7.5” wide like the steelies?
Old Dec 2, 2021 | 09:46 AM
fordmantpw's Avatar
fordmantpw
Those are from a 2005-2007 Super Duty. Whether they will clear the calipers or not, that I can't answer.
Old Dec 2, 2021 | 10:55 AM
Joe T's Avatar
Joe T
Those are worth some decent $$ to someone looking for them.
They should fit though. Same pattern and offset since that style.
You can google the width or check it on tirerack various ways.
Old Dec 2, 2021 | 11:20 AM
mewaschuk's Avatar
mewaschuk
also fyi, the lug nut head shape changed around 2017 and the older center caps will not fit new trucks without the old lugs.
Old Dec 2, 2021 | 12:55 PM
El Chupacabra's Avatar
El Chupacabra
This probably explains why I had such difficulty pounding on the center caps on my winter wheel set - using current lugs nuts (2022) with circa 2013 wheels and caps.
I should probably track down a set of proper lug nuts.
Old Dec 2, 2021 | 01:17 PM
mewaschuk's Avatar
mewaschuk
yup.
i just put 2018 wheels with 2014 caps on my 2020...factory lugs pre 2017 work just fine on the post 2017 wheels.
Bishicka
24
Aug 25, 2021 03:26 PM
JKimber
Dec 8, 2017 01:24 PM
whiteboyslo
Feb 8, 2012 11:07 PM
mr_malina
18
Feb 5, 2011 02:56 PM
Hans77
18
Apr 13, 2007 07:31 PM
