Sponsored by: Auxito
Starter engages while engine is running.
Old Nov 29, 2021 | 10:10 AM
bcompton35603's Avatar
bcompton35603
A few weeks ago the starter kept trying to start the truck when I was inside the house with the key in my pocket. The radio would a)so come on. I removed the lock cylinder and the plastic around the steering column and there was a plastic ring around the lock cylinder that held a metal clip that had broken and was touching metal. Could not find a part number for this so I used gorilla tape to fix it. It's worked up until this past weekend. I cranked the truck Friday morning to let it warm up and every 15-20 seconds the starter would engage and I noticed that the power would go out at the same time. I'm wondering if it has to do with that broken piece around the lock cylinder or ignition switch?
Old Nov 29, 2021 | 11:42 AM
projectSHO89's Avatar
projectSHO89
No.
Been raining there?
It helps if you explicitly identify what you are working on....
Old Nov 29, 2021 | 11:51 AM
bcompton35603
It's a 2000 F150 5.7 and it hasn't rained any more than usual. I can't tell that the windshield is leaking, carpet doesn't seem to be wet. I've read about the GEM module getting wet. However there is a bit of rust in this old truck so I was going to look to see how the ground connections look. Starter and battery was replaced a few months ago.
Grupedog
Dec 29, 2017 09:55 PM
djc1978
Nov 29, 2016 08:34 PM
crkrstf
Mar 8, 2015 07:17 PM
dvldog458
Feb 2, 2005 11:45 PM
DaverL
Oct 3, 2004 07:02 AM
