Brake question
Old Nov 27, 2021 | 11:44 PM
Dentside1974 highboy's Avatar
Brake question
New to the forum, I have a 1974 f250 highboy that had drum brakes front and back, I swapped the front end out for disc brake front end out of a 1976. My question is do I need to get a different master cylinder and proportioning valve?
The disc brake front end came out of a 1976 f250 4x4 with a auto trans, my 74 has a 4 speed
Old Nov 28, 2021 | 01:27 AM
SonofaFord's Avatar
SonofaFord
Yes. The reservoirs are different for disc vs. drum. Can you get the MC and valve from the 76' that you got the brakes from?
Old Nov 28, 2021 | 01:28 AM
Christmas's Avatar
Christmas
As many have said, the master needs to be correct. Just find one that pumps fluid. Which ever one you choose a proportional valve will be needed to control the rear bias.
Old Nov 28, 2021 | 01:30 AM
85e150's Avatar
85e150
Both disc and drum need residual pressure, but in different amounts. These valves are usually right on the master cylinder where the lines screw in. So research that along with proportioning.
Old Nov 28, 2021 | 12:18 PM
The truck is no longer available to get parts from anymore,my truck has a duel reservoir mc , a big one and a small one, so can I just buy a mc and proportioning valve for a 76 and install on my truck?
Old Nov 28, 2021 | 06:25 PM
jackietreehorn's Avatar
jackietreehorn
Yes buy a 76 MC and one of the generic disc/drum brass proportioning valves carried by LMC, Mac’s NPD etc..
You will need to make or buy some additional brake lines and may run into some fuss with the booster—piston rod length, travel, etc…?
Also, you will need delete existing differential valve.
Old Nov 28, 2021 | 06:52 PM
Brakes
Thanks for the info I appreciate it.
ssme2
1997 - 2003 F150
Apr 18, 2020 06:48 AM
crazed87bronco
Dec 3, 2010 09:17 AM
talbotmatt
Nov 17, 2006 12:15 PM
crustyone
Aug 21, 2004 02:53 PM
