Fuel delivery module wiring
Old Nov 26, 2021 | 03:22 PM
Brett Thomas's Avatar
Brett Thomas
Anyone have an opinion on the wiring pictures, not working correctly. 95 Ford F250 5.8L dual tanks. Thank you .
Front tank
Rear tank
Only wiring diagram I found for aftermarket FDM
Old Nov 26, 2021 | 07:53 PM
My4Fordtrucks's Avatar
My4Fordtrucks
According to that chart, I don’t think you have the wires correctly matched up for the rear tank. What problem are you having that you replaced both pumps? What brand has you splicing the wiring? The Spectra pumps I used on my ‘89 plugged right in.
Old Nov 27, 2021 | 09:38 PM
subford's Avatar
subford
Maybe this will help:
Old Nov 29, 2021 | 05:32 PM
wwhite's Avatar
wwhite
Looks correct to me.
What is not working correctly?
Fuel gauge broken?
No pumping, only one pump works, one pump overfills the other tank?
Old Nov 29, 2021 | 05:57 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Seems most aftermarket units have you swap the harness plug, no clue why. Bought one for my '92's side tank and saw same issue.
Two are for pump, two are for sender. Not really much to it aside from the nuisance factor. If in doubt, even a cheapass DVOM from Harborfreight will show you power to the pump and its ground.
Black on US stuff is almost always ground. Brown on Euro cars is ground (think Earth aka dirt color). Easy to find out with a basic continuity test to battery negative. Positive switch for pump, just use a test light once ground sorted. No clue what would happen if sender wires reversed, maybe it will read backward...so wire one way with float zip tied up fully, key on. If registers full, remove tie, recheck gauge. Obviously faster with help. Also, the larger wires should be for power to the pump to narrow down faster.
Let us know what you find out as this pertains to me and will save me time.
Old Dec 10, 2021 | 12:32 PM
Brett Thomas
You were correct
You were right 2 of the wires were not correct. But even after fixing the wiring the rear tank still overfilled and pumped gas into front tank. So I broke down and brought it to a shop on Tuesday. He said everything I did was correct and the only solution was a bad pump. It did cross my mind I bought a new pump in August of this year. So I went back to AutoZone because it was lifetime warranty got a new pump. It's only been two days but so far so good. Both pumps are acting correctly ,but I am waiting to fill them up again before I claim success and put the bed back on. Thank you for all your responses.
Landman 454
May 18, 2021 02:54 PM
77ford250
Sep 14, 2020 03:58 PM
nrbacarl
Apr 4, 2016 01:26 PM
sidewaysstarion
Nov 24, 2015 09:39 AM
SideWinder4.9l
May 5, 2012 11:57 AM
