Sponsored by: Auxito
Soft brake pedal
Old Apr 5, 2018 | 05:16 AM
z56's Avatar
z56
Soft brake pedal
Hello , I have a 1997 f150 4x4, 5.4L, the problem is I have a very soft brake pedal. I have replaced every component of the brake system except for the brake pedal itself. This includes the master cylinder, vacuum booster, all hubs rotors bearings shoes pads and brake lines. I have braided steel brake lines. And yet for some reason, the brake pedal is real soft and mushy. It's almost like I had manual brakes. I have been told that this type of truck is known for bad brakes. Can you guys help me with this?
Old Apr 6, 2018 | 09:17 AM
alloro's Avatar
alloro
If you have a soft pedal that means there is still air trapped in the system, nothing else will cause this condition considering the parts you've replaced. It might need to be power bled.
Old Apr 6, 2018 | 09:28 AM
z56's Avatar
z56
Bleeding the brakes
I believe your right . I will talk to the shop about it. They have bled the system twice, but I suppose air could still be in it. Thanks for your reply. :-)
Old Apr 6, 2018 | 12:27 PM
pdqford's Avatar
pdqford
Be sure that the bleeder valve for each caliper is at the high point of the caliper.
It is possible to put a caliper on the wrong side or put the wrong caliper on.
I f the bleeder valve is at the low point of the caliper you will never get all the air out of the system.
Old Apr 6, 2018 | 12:44 PM
z56's Avatar
z56
Bleeder valve
I will take a look at that. That's something I didn't think of.! Thanks :-)
Taylor Doyle
Mar 24, 2017 07:46 AM
subzero32
Sep 21, 2016 06:35 AM
SHOpar
Jan 27, 2014 09:18 PM
tibailey
Feb 27, 2008 03:37 PM
captjohn
Oct 24, 2004 05:07 PM
